hi everyone, new poster and new wood stove insert owner.
I've been lurking the boards for a few weeks now and I tried to find the right answer but really haven't been able.
Here's my setup. I purchased a VC Merrimack about a month ago and trying my hardest to figure out the "right burn" for it. I have a 2000 sq ft 2 story colonial built in the earily 70's.
It's been around 30-40 degrees out and I'm getting 56-58 inside my home with all systems off.
I'm looking for advice on the following
When the stove is running what should the air temp from blower be in a range?
I'm seeing 150-250 max on all different speeds and at all different air levels it just seems odd that the firebox hits close to 1000+ but the surface temp from blower air is only 250.
When I do get the air temp that high I can only seem to get the temp
In the house no higher the 62. In the room it's max 68.
I was told by several people that the room should be blazing hot (80's). I'm just not seeing the hot temps that people are saying.
I've got dry wood (11% ) so I don't think it's a wood issue. Thoughts??
Also how fast should I be going though wood? I'm a 1/2 cord used in 4 weeks that seems really high....
Finally anyone have any real suggestions as to getting air out of the room and into other areas of the house? I'm going to be pulling down a wall which will open that room up more but not until spring.
I guess I'm just disappointed with this unit I really thought it would give be a healthy heat in the house and for the cost I'm just not happy. Any suggestions would be helpful!
Thanks
Thanks
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
