What's the thinking on this? Feasible to store sufficient geo-thermal heat pump produced hot water during daytime electric production to make it through the night or cloudy period? Other ideas?
Probably not a good option to store geothermal produced hot warm water as geothermal heat is generally relatively low temperature, thus the storage needs to be huge. As long as net metering remains available it is the way to go but as non dispatchable renewables like solar increase as a proportion of the grid, I fear that it is going to be chipped away by the utilities. At some point real time pricing is going to appear which will shift a portion of the burden for high heating season power demand into the consumers laps and I expect even the folks will net metering will be clipped by that shift.
Ultimately the best investment is energy reduction. Spend the money to build a net zero energy house and on the rare times you do need heat, run a small woodstove. Unfortunately, most folks want to keep their current home so the net zero house is unlikely although deep retrofitting of a current house can substantially reduce usage.
Off gridders in northern climates have already worked out solutions to this and generally it entails wood heat, solar panels, a battery bank good for three days, a back up generator and a willingness to change their lifestyle to adjust to low energy use.
