I just stumbled upon this topic, and figured I'd chime in with my experience since I've had the Geospring for about a year now. I originally had an oil-fed hot water heater, which sprung a leak last year. After researching, I decided to replace it with the Geospring... less dependency on oil and all that jazz. My unit is in an unheated, unfinished, humid basement. The instillation went great... only took 2 or 3 hours. If anyone in central mass wants an experienced plumber, let me know... my guy was great and he did his research before he came to inspect my old setup. It was up and running mid-August 2010, and I had it set to Pump-only mode. My wife didn't notice any differences... so no complaintsAround November, I did start to notice a difference in water temperature. My wife showers first in the morning, and then me. The water was noticeably colder (but not cold... more luke warm). This is because of my low temp basement that houses the unit. To combat this, I raised the set temperature and put it in Hybrid mode throughout the winter... water was much better. When we have company over, I put it in high demand mode, just because I don't want my guests to notice anything. In may, I went back to pump-only mode. As for cost, since I didn't have a standard electric hot water heater before, it's hard to compare. But in the past year, I'm noticing a $50 dollar difference each month. But again, the flip side is I don't have to order oil every year, so you can do the math there
Overall, I'm very pleased with the unit. I like that I can set the controls based on my needs any given day/week/month. If anyone wants other specific information, let me know. Cheers!
I' just hit 3 years with my Geospring and no complaints. I posted the following 2 years ago in the DIY forum, but I'll paste it here in case it helps anyone.
A few updates since then... I've used the Vacation Mode several times, which is a nice feature. No issues with hot water when I come back from vaca. Also, I've only gotten the "clean filter" alarm once in 3 years... so very little maintenance. I stopped putting it in Hybrid Mode in the winter because I read that if it's in Eco mode (pump only) and it can't maintain the temp, it just kicks on the electricity anyway, so I wonder if there's much of a cost difference (???).
Anyway, like I said... no complaints what-so-ever.
Would you mind posting what you are charged per KWH?
I know the oil savings offset the increase. 50 increase a month is a crap ton where I live. I already have electric water heater so don't know if it's worth it for me.
6.89 cent's a kwh here, you will save alot of $$ if you already have a energy hog electric hot water heater, my basement does get down to 45ish in the winter, so I will switch it over to Hybrid mode by Nov.
WKB, why would you have to add a code to reset it?, why couldn't you just switch over to electric mode?
I think if you took your final total and divided by number of kw used it would be much higher. Usually there is a delivery fee as well that is charged per kw as well.
So your saying your very expensive 13 cents is including delivery fee's?, 4 yr's ago we were at 12 cents
Does anyone have any idea how effective these are at dehumidifying a room? My basement dehumidifier was part of the recall, so I need a new dehumidifier. However, my propane water heater is also 16 years old, and I'm just waiting for that to die.
I'm tossing around the idea of switching to a heat pump water heater. The downfall is that I'll have to have a wire ran, which isn't going to be cheap, and I think my propane supplier is going to start charging me rent on the tank if my propane consumption falls that far down, and the two of those could really negate any savings the heat pump gets me. I'm already under the amount on my contract, and going to electric water heating is going to put my propane consumption down to almost zero. Still need it for backup heat though...
, better than that $120 i blew last night eating at Cheesecake Factory....was not impressed
Also keep in mind that opposite of the dehumidifier, the heat pump will cool the air around it.
I bought the GeoSpring the first year it came out. It is the best investment I have made for the house energy wise other than the pellet stove. I never heated water with Electric. It was always the boiler and when the pellet stove went in we were running the boiler to get hot water. My boiler is incredibly efficient and I had a 40gal separate stainless hot water storage tank yet it still was using a crap load of oil. When I shut all this off and turned on the Geo the electric bill went up $7 a month. There is only 2 of us. GE is fantastic. My unit failed and was out of warranty. They fixed it for nothing. It seems they were made in China and they used cheap material for the condenser. The repairman informed me they turned out so successful they now have an entire GE division up and running over here and Mexico that is using only US made parts. On the plus side my basement is way cooler in the summer and much less humid.
The old units had problems with chinese made heat pumps. Current models are made in USA and have been reliable.That's the scary part. I've read a ton of reviews and they pretty much start the same "I had to have it repaired but now it works great." Sounds like these things are designed to have a breakdown.
what rebates did you get? i'm in ct as well and can only find federal ones...With a meter reading coming oct 2nd looking at my meter i've only used 600kwh so far, thats alot less than the 1900kwh i used in july because of non stop a/c's for a month, i just mailed in my rebate today i'm very pleased so far with this heater, our hot water is alot hotter than the old heater which was only 5 yrs old and my dishes come cleaner in the dishwasher also, best $199 after rebates I've ever spent, better than that $120 i blew last night eating at Cheesecake Factory....was not impressed
