HI ALL ,anyone have this cap or know if it is worth the $80 for it . I like the way it can be opened to clean the flue without removeing the whole cap but can a strong wind flip it open after its been used a few times ???.... Another Question is about Chimnney Saver Sealer .I want to take all the paint off the chimney because it is peeling.... The chimney is 21 blocks tall 8" x 15.5" blocks with 8" flue tile non cracked with only the top four blocks visable on all four sides....All the upper 12 blocks ( from thimble up) have hairline cracks on sides so I would need to use a masonery silcone or ??? product to cover them .The crown also has a couple of hairline cracks ,Chim S also have a crown sealer for that...I am not sure if I need to remove paint, use Chimney seal and then chauk cracks on block or remove paint, chauk first than seal with Chimney Saver....None of the Sweeps around here that have it will sell the Chimney Saver products unless they get the job to do the work but I can D.I.Y and get it online but I may have to buy more than I will use. BTW I am having a 6" Forever Flex brand ss 316ti liner put in to match 6" new woodstove.... Thanks Mario
