No, but you will not be able to drain fuel again until the fuel pump re-establishes the syphon.When it's empty, it's empty. Did you expect to keep siphoning fuel from an empty tank?
Actually the carb bowl should have enough fuel in it to start the truck and then the fuel pump would re-establish flow in the line rather quickly once the tank is re-filled.Could be lots of cranking to get the air out of the line.
The fuel line comes out the top of the tank. I think I am back to looking for a good pump, or siphon hose.
Yes but within the tank, the outlet runs in a tube that goes to the bottom. The fuel line that you see on the top of the tank takes off and runs down under the cab right? If you cut that line under the cab it will dump the fuel tank.
But i'd have to start the siphon. Or are you all saying that the engines fuel pump starts the siphon. Then I open the T valve and then shut off the engine and let the established siphon do its thing? I guess I' a little slow.
I think that they needed to be driven by the burner motorI don't know if an oil furnace pump would be compatible with gasoline or not. Find an oil furnace someones swappin out for nat gas and your in cheap.
You can do the same with a can of gas and nothing will happen. Now a match on the other hand.....Yes, gasoline is rated totally different than diesel/oil fuel. You can stuff a lit cigarette into a can of diesel and it will not explode or catch. Gas can, not so much.
I personally know men that turned to krispy critters because they poured gasoline on a stump that was not on fire. Coals are enough to ignite gasoline. I do admit that I have never put a cigarette into a gas tank. Non-smoker here.
