ricks said:Can I go from here to here? Can I connect the two ends of the headers together?
BrownianHeatingTech said:ricks said:Can I go from here to here? Can I connect the two ends of the headers together?
Yes, that was the suggestion.
You need a pump to create flow through the loop, obviously. The advantage is that it will be needed when you replace the existing boiler, anyway, and it will keep the boiler hot (tees in the return will only transfer heat into the boiler when a zone is running).
Joe
ricks said:So, can the Hx be in that loop with one pump pushing water through the whole works
( the boiler, both headers and the hx) OR does the hx loop need to be tee'd into the boiler loop?
BrownianHeatingTech said:ricks said:So, can the Hx be in that loop with one pump pushing water through the whole works
Either can work. Having the HX separate gives a greater degree of control, but requires a second pump. It's a balancing act.
Joe
ricks said:BrownianHeatingTech said:ricks said:So, can the Hx be in that loop with one pump pushing water through the whole works
Joe
Control of what? When each pump starts? Pump speeds?
Jim K in PA said:ricks said:Another plan was to cut two close tees in here and be done with it. Might be simple enough..................
Rick, if that is your return leg, that is where I would (and did) put in the close Tees and valves. Here is my splice:
I should have some more pics posted of the HX connections and piping soon. I'll also have my control schematic finalized and posted soon, too.
Rick Stanley said:Jim,
I see, in your pic, that you have a ball valve between the close tee's in the return of the boiler. Normally, in drawings of p/s piping arrangements I don't see that. Now that your new system is running, do you have that ball valve closed to ensure that ALL of the return water MUST go to the Garn HX to be re-heated before re-entering the boiler?
Thanks,
Rick
Jim K in PA said:Rick Stanley said:Jim,
Thanks,
Rick
10-4. It is probably not necessary, but I decided to install it anyway. I wanted to ensure 100% flow through the HX. It is not really a P/S piping setup on this side, just a diverter to the HX. I only have the original little TACO 007 pushing water through that leg into the HX and then into the boiler, and then into the zones (high head, ya think?). It'll all be revised when I delete the oil burner in a year or two anyway.
Rick Stanley said:Makes sense to me. I have a similar set-up, but with a Taco 007 on each of the seven zones, pumping away. When I look at the possibility of putting close tee's in the return leg I always wonder what would keep the water
(at least of of it) from shooting past the tee's and into the boiler again without going through the Hx, even with an added pump between the tee's and the hx helping out. Since my goal will be to keep the boiler hot for inhanced dhw production with less (hopefully none) oil use and it's not p/s anyway, I like the ball valve there.
(maybe could use some kind of automatic valve)
I wonder how low I can let the oil boiler temp get and still make dhw??
Jim K in PA said:Rick Stanley said:Makes sense to me. I have a similar set-up, but with a Taco 007 on each of the seven zones, pumping away. When I look at the possibility of putting close tee's in the return leg I always wonder what would keep the water
Rick - the dhw coil in my furnace is the exact reason I went this way. However, the dhw situation is the biggest disappointment I have so far. The amount of heat transfer to make 120 degree hot water through that little coil is staggering. Unless my GARN supply temps are above 170 AND there is at least one, and preferable two, zones circulating, a shower will bring down the boiler temp below 140 pretty quick and the oil gun will kick on. It shuts off before the shower is done, typically, or within 30 seconds of shutting off the hot water. The amount of oil used is relatively small, but it still annoys the crap out of me. I think Tom Caldwell said he put a 1/2" bypass line and a ball valve between is supply and return legs to keep hot water flowing through the furnace and the coil hot. I am going to delete the oil burner next year and install an indirect wh.
