Como said:Well we have hit a glitch, delayed us a few days. Plus the wind last week kept blowing the plumbers torch out. We are still unseasonally warm, have not been below 0F for a few weeks.
One thing I did not know, never seen it mentioned here or in the documentation, and which I will pass on is that when you have more than one Garn they should be operated together. My original plan was to operate both in Winter and one or the other in Summer.
Also you will see that each Garn had its own Pump, there must be one pump for all the Boilers.
Hopefully this will help anybody else considering a similar set up.
Como said:Well the guy who designed the system, all now operational ex Garn's, is now retired but has done thousands of systems. But not Garn's.
The info came from the top at Dectra.
Apparently with Garn's that is just the way it is, obviously with other Boilers, like my Triangle Tube, cascading systems are normal.
Anyway I had to get the W2's out and I still have year end accounts etc etc, so I will get it done the recommended way. I know we will get hit with bad weather soon.
Frozen Canuck: David: as far as I can tell from your post & this thread there is no reason that one could not run those 2 boilers however you choose.
jebatty said:Frozen Canuck: David: as far as I can tell from your post & this thread there is no reason that one could not run those 2 boilers however you choose.
David says that the info that they cannot be run together --The info came from the top at Dectra.
In my experience if Dectra says something and if an owner does something contrary, then Dectra may take the position that the warranty is void.
maple1 said:I am thinking the Garn people might have issues with using shut off valves to isolate one of two boilers, as they could see potential for someone to light a fire and forget to open valves - which would be a bad thing. Just a thought.
