Try this link to the Warmly Yours heat loss calculator. I just tried playing around with it and it looked pretty good. http://www.warmlyyours.com/hlc/room/index_main
Mike
			Mike
   A garn is big and will take up considerable room.  I think the final dimiensions of my Garn cube (the box around the garn with all the insulation) is about 8' wide, by 9'6" long, and just under 8' high.  Remember you have a HX somewhere in this shed (or maybe in the house), you have some other plumbing, you want to be able to access this plumbing, etc.  bpirger said:If you want to put a Garn, a 4wheeler, and 5 cord of wood in a 24x12 shed, I sure hope it is at least 3 stories high and you plan to move lots of wood upstairs!A garn is big and will take up considerable room. I think the final dimiensions of my Garn cube (the box around the garn with all the insulation) is about 8' wide, by 9'6" long, and just under 8' high. Remember you have a HX somewhere in this shed (or maybe in the house), you have some other plumbing, you want to be able to access this plumbing, etc.
I could likely fit 2 full cords in the building if I wanted to pack it rather full....but I don't think I could fit the 4wheeler in there, at least not and move around nicely.
Just some thoughts....
BHetrick10 said:If I knew that the froling would work I think I would go that route. Seems real user friendly and efficient. I am scared of a 10,000 + dollar mistake though. I like how this style of boiler can pick up and go if the house is cold and bypass the storage.
This is what I dont like about the garn. You cant bypass the storage. At the same time that is what makes it a Garn. Real simple just a little less efficient, but it is not as picky as what you feed it.
I was told a Solo 60 may work rated at 198,xxx BTU/hr. They seem to have a good track record?
How are you guys doing the heating calcs?
Thanks for the replies
