TCaldwell said:leaddog, my garn modulates via a in situ fluegas analyser, allen bradley plc , hitachi vsd and 2hp 3 phase motor
Hey Tom,
How is that setup working out? Is it a big advantage? Does it ever get "confused?"
leaddog said:Hay guys don't get me wrong cause I REALLY REALLY like the garn and think that it should be looked at first in alot of situations. That said, There is a market for a residentual chip burner. Just look around and look at the available fuel supply. Chips are available every where locally. very little processing, cheap, easy to handle and you don't need to use valuable timber. You can also use cherry pits, peachpits, nuts, wood pellets, hay pellets. If you have one that modulates then you don't need storage and you are getting closer to having a easier boiler that everyone can run and understand. I'm getting older and someday I just might not beable to cut, split, stack, and handle wood. Thats one reason pellets was a very serious thought for me but pellets are still at the mercy of oil where chips are right here in my back yard.
leaddog
TCaldwell said:chiptec in vermont makes several models of chip boilers,its not the cost of the boiler but the conditioning and delivery system of the chip that makes it out of residential reach. they use cleaver-brooks controls with a ametek in situ flue gas analyser. my experimentation so far with cordwood and 02 control is a '' compromise because of the burning stages of cordwood , start-up, with a time period of 02 deficit , next stage a optimum combustion with a 2to 4 % 02 reading, next stage about 2/3 through burn, o2% will gradually rise to about 13% about 75% coals and a few small logs left. the last third basically just coals will rise from 13 to 20.9% end of burn. in the garn when it puffs the o2 reading is at 0%, so in a nut shell with a static fan speed , under aired for first third of burn a good o2 range for second third of burn and over aired for last third of burn. this cycle can be manipulated with size of splits, frequency of reload and moisture content. i suspect most '' lambda controlled'' cordwood boilers are designed to try to limit theses '' compromises''by carefully designing fire box capacities and reccomending small splits, primary/ secondary air ratios and volumes to try to minimize the cordwood burn cycle swing. I am in the process of defining and testing programable runs in the allen bradley plc for different moisture content wood. one button for a program that will controll dry wood,another for average wood ,and a third for less than optimum wood., these programs basically differ in initial static fan speed start-up time, also looking to end burn with a declining flue temp for a given length of time, and of course a overide toggle to run manually. this experiment, ongoing is leading me to believe that a continious fuel delivered system, pelletts or chips for example is more successfully controlled with o2 control. i would appreciate any comments or ideas that you think might be incorporated, thanks
tom
leaddog
TCaldwell said:Brad, at 70hz you get away from the puffing but will still read 0%o2 at 80 hz fan speed. i agree that the primary/secondary air would have to be reconfigured to optimize, have not talked to or heard from the switzer boys, i should call them.
tom
heaterman said:RE secondary air: I've often wondered what would happen if the secondary air stream in a Garn was "ducted" directly into the refractory chamber..........just thinking out loud.
Garnification said:Guys, I and High E experimented with all different setups and settled on the original concept. One test run, I made up a tubing grate that the wood and coals sat on and it was stuck into the bottom combustion air hole and ran at a slight incline to the start of the secondary chamber. It didn't do any better than the original and actually the thermometers that are in my flue passages read lower.
Happy New Year Tom and all of you here at Hearth.com,TCaldwell said:heaterman, gary switzer built a boiler for ed forest, a hearth member that i saw in action last may. It was similar to a garn in concept of a primary chamber/secondary reaction chamber, the dimensions were different than a garn, however it had a 2 inch dedicated secondary air supply that was damper controlled by a flue stack thermocouple, it terminated on the back vertical wall about 18 inches away from the secondary reaction chamber. when the flue temp reached ? the damper opened introducing o2 next to the src, but not in it. switzer claims about 850kbtu/hr out of a 6'' id refractory chamber that is 5ft long. he has 3000gal water in storage. the best readings with the testo 327 were in the high 70% range.
heaterman said:EUP of MI said:Nice job heaterman. How many inches of insulation did they install (thickness). Is this product available through a company like State Supply? I'm building legs for my unit so that I can get insulation all the way underneath.
Thanks
Allan
Thanks Allan
The owner placed the Garn on 4" of foam and the mineral wool is a full 4" thick. As you can see from the pics about 3/4 of the unit is bulkheaded into the mechanical room which is of course heated to a certain extent by the piping so heat loos from the jacket will be very minimal. There's only about 18" of it protruding into the presently unconditioned space in the Garn Barn/wood storage/machinery building. That area is un-insulated at present but does have tube in the floor and I would imagine at some point in the future it will be heated as well. All I can tell you on the insulation is that the owner bought it from some place downstate. I will be doing some research on sources and types and try to post my findings here.
EForest said:All you Garn Guys: how much wood do you burn for heat and DHW.
EForest said:BTW I resolved the "puffing" issue if any are interested...
EForest said:Jim K
How do you raise 2000 gals of water 40* with only 40-60 lbs of wood? the math doesn't work. Are you using other sources to heat the water? I burn @ 300 lbs to raise 3000 gals 70* ( this is a guess based on cu ft because I've never weighed my wood).
tigermaple said:Heaterman,
What was the cost of such an install?
