Full masonry brick and concrete blocks wall hole size
cottonjoe
3
Canada
Hi and thanks in advance for the help.
I got this indoor masonry fireplace that has an indoor masonry chimney in the living room. It is location in the middle of my house. I am preparing to make a hole in the back of the fireplace (on the dining room brick wall) to install a brand new wood cook stove 6 in stove pipe. I ordered a 25 ft Flex liner kit with the tee and detachable snout.
Dining Room
[Hearth.com] Full masonry brick and concrete blocks wall hole size
Living Room
Inside fireplace (the hole at the beginning of the dark area is my pilot hole from the dining room)
The idea is to get the chimney SS liner tee into the fireplace chamber to have easy access to the bottom cap and get the tee snout to cross the 21 inches of bricks and concrete blocks with a SS rigid Pipe extension since the snout is only 10" long. There are no combustible materials whatsoever inside this wall. Around it, the closest the pipe would be from combustible is 3 feet away.
Two questions:
Is it an appropriate setup?
What kind of clearance do I need from my SS rigid Pipe to the bricks and concrete blocks inside the wall
I would like to keep it as narrow as possible like 6 3/8". If need be, I was thinking about making a hole about 8.5" wide and insulating 1" around the pipe and snout with maybe this Ceramic Fiber Blanket (Amazon) so that the concrete blocks wouldn't break due to excessive heat.
Thank you again
Dining Room
Living Room
Two questions:
Thank you again
As long as it's solid masonry with no combustible wall in between it can be pretty tight. I usually add a 1/2" or so
