force air system
kgryder
22
NC
I've had a Econoburn boiler on order for a while. If it ever gets here I will be setting it up without storage. I hope to add storage later but space is a problem right now.
I will have a Superstor tank for DHW.
My present system uses a oil fired boiler and pumps water through a heat exchanger in my forced air system.
Since it is a forced air system I need to have hot water in the heat exchanger before I turn on the blower.
So how long will it take an idling boiler to get up to temperature when I call for heat?
I'm also trying to decide the best logic to use in switching to oil fired heat. How long should I wait on heat from the wood fire before I give up and fire up the oil burner?
Thanks for your thoughts.
I have a simple digital temperature controller that turns the blower on when the heater core exceeds 125 degrees and keeps the blower on until the core gets below 80.... My thermostat does nothing to the furnace, it just turns the pump on.... The temp sensor on the heater core turns the blower on and off...
Matt,
Could you give more info on the temperature controller and sensor for the heater coil.
Brian
