P.S. You can find a lot of good advice here: http://michaelbluejay.com/electricity/whyhigh.html including how to find out if your circuits are leaking power.
I'm not sure what this might mean, but does the meter read anything with the main breaker off?
Maybe you could turn everything off and see what the load is?
Maybe turn a breaker on one at a time?
Highbeam, don't you have a detached shop / out-building? Are you accounting for what's being drawn there?
Sure it is not the hot tub?
"The actual usage will depend on several factors such as size of the tub, the outdoor air temperature, the insulation levels of the tub and how often the top is off the tub. Older hot tubs average between 10 and 20 kwh per day. That translates to about $25 to $50 per month on your power bill. Newer, energy efficient models use between 5 and 7 kwh per day or about $12 to $17 per month."
from: (broken link removed to http://www.clearwaterpower.com/BobsBlog/default.asp?Display=48)
Sounds very much like the amount of base-load electricity you are looking for.
Added on: Wow, that is a lot. At 10 kWh a day that is roughly 1/3 of the electricity consumption of an average household. We are really spoiled by the cheap energy we had all those decades.
We just recently got a smart meter installed. Our power utility provides hourly data which really shows the base load (usually ~0.1 kWh) when no one is at home or we are sleeping and what we actually consume. I can even make out how much the washer, dishwasher etc. draw just by remembering when we turned those on. The fridge also seems to come on more often now. Any way you can get those data from your utility?
One start in energy savings would be to turn the shower off while lathering up. Good luck convincing your family though...![]()
I have not ruled out the spa yet. It is about 10 years old and was one of the 10,000$ models with spray foam insulation. We do shut it off every summer for at least one month and the bill for that month is only slightly lower so yes, it might be the source of 5-7 kwh per day. Indeed a large part of the base load.
Power is still very cheap IMO. I just don't want to waste it.
I am wondering whether the reason you saw not a large reduction is because you have an AC running during those months or your fridge/freezer draw that much more. Even if your hot tub is a very efficient model with "only" 5 kWh per day that is 150 kWh in a month. You should be able to make that out.
Yep, 3 kWh are only 30 cents but it is also 10% of your daily consumption. Cutting that in half is a 5% reduction right there. You have to start somewhere.
Btw. How many lights do you have in your shop? 8 amp are 900 watt of lighting. Are those fluorescent lights or incadescent?
Propane heat primarily, wood at weekends. We still have electric baseboards too but now that we pay full price for that, they'll be used even less than before. Hot water is electric, lots of laundry, everything goes through the dryer. I pay less for electricity than telephone most months, so if I need to cut my budget, the phones will be cut first...All electric, wood for heat only?
...electric tanks have very quick recovery times. When I turn mine on, the temps start rising almost immediately.
Seems funny to focus on smart meter electromagnetic radiation when there's so many more sources of it out there.Sheesh, these smart meters sure have gotten a lot of people excited. It seems people fear some sort of sickness from the communication system.
... only cost an extra 30$ per month to operate. That's 300 kwh in my house.
I just checked and we are using about 16.5 kwh/day right now for 3 persons in an all electric (old) house. A couple of weeks ago with the heat pump running it was about 24kw/day. This is offset by us averaging about 13kw/day solar generated power in May. June should be even better.
I was surprised to see that too. Our appliances are new and energy star rated, but I run computers plus an office space heater when it's chilly. Not sure why the disparity. I just got onto PSE's website and checked our consumption for last weekend while we were away. It was 9.59 kw last Saturday. This was with the hw heater still on and several vampire loads. Yesterday's consumption was 19.1kw, but with 18.2Kw solar generated @ $0.64/kw, I like that.
One thing I was wondering about, do you have a well with a pump? If so, check to be sure it's not short cycling due to low air in the pressure tank.
