woodgeek said:
I agree with highbeam....you should go electric, and get a 60-80 gallon, well insulated tank (usual 'rule' is 20 gallons per bdrm). Your boiler is aok being shut down for the summer. The standby losses on a modern electric tank are very low.
If you want more numerical proof, you have to estimate your standby losses in the summer.
I put a run timer on my boiler to track my usage accurately. My boiler has no calls for heat cuz I switched my heating to a HP....
My wife and I and two young kids use ~100 gallons of oil in a tankless coil, per year to actually heat water that was delivered. But my boiler still burns ~300-350 gallons a year. AND I up-insulated the case AND eliminated a thermosiphon in the hydronic loop. So, minimum I am burning 2+ gallons of oil on standby for every 1 I burn to heat water. If your standby losses are similar, you are spending >$1000/yr on DHW.
To estimate YOUR oil standby, take your summer usage, and subtract off maybe 0.2-0.3 gal/day for actual DHW delivered.
This is pretty interesting. A couple of points I'll comment on with more questions.
PSNH - power company for NH reports $77 per month for dhw from an electric tank. Maybe they are overpricing it, but if anything, I would think that they would underestimate it. At $77 per month, I'm talking $924 per year which would be the same as burning .87 gal per day at $2.91 per gal. A little low for oil, but my prebuy price is 2.99 this year.
Can you explain how you came up with the 100 gal for dhw, but 350 total. I get the total, but don't understand the other. I have been tracking my usage for 10+ years with my old and new boiler. The least average usage I saw in the summer was .87 gal per day. When I looked at the system 2000 website they indicated the oil usage in the summer should use .2 gal per day for dhw so the .2 you have above sounds interesting. My heat is definitely turned off in the summer. The only thing I couldn't tell from the system 2000 web site is if the .2 was for their solar/oil unit or just the oil unit.
Can you show me the timer you have on your boiler. I could use that in the summer when the heat is off so I could get an accurate reading for dhw oil usage.
I'm leaning towards solar since it will be almost free once it is installed. Just cost a little for the electricity to make the pumps run.
Thanks again
