Are you talking 500 interior or exterior measured flue temp?
Joful, I'd be concerned if it were my stove getting the flue that hot all the time. Maybe especially in your case, with that wood in your chimney....I'd be interested in knowing next year if you are able to engage the cat with a lower flue temp once your wood is dryer. Hope so.
500 - 600F on the exterior of the single wall, measured using an IR gun, about 6" above the collar.
No wood in this chimney! That was what one inspector/installer tried to claim, and tried to sell me a $9000 plan to fix the problem. I proved he was wrong, then made him come back, reinspect, and give me a new report confirming that what he said was wood, was really brick. I should really post those reports one day...
That 500 f. for the singlewall connector pipe is measured by mag. condar thermo about 4" out of the collar. What it takes to burn without smoke from the flue is based on experience and a thousand runs outside to peek at the chimney. After the damper is closed, the flue pipe temp. drops to 300-350 where a long smokeless burn happens. Yes, I find that the flue temp. Is alot better an indicator for when to close the damper and when you're burning smokeless. With the Encore, you can have a cool flameless firebox (300) and HOT cat chamber (750) with no chimney smoke. BTW, the Encore does have a built-in cat probe of sorts- the bimetal secondary temp probe turns in proportion to the refractory box temp- just remove the cover to see it.
Similar here. A few minutes after engaging the cat, my single wall drops down to perhaps 225 - 250F. Five or ten minutes after cat light-off, I can
usually have the stove top down to 350F with the cat crusing at 1400F - 1500F. Cat usually peaks above 1700F an hour into the burn, still with stovetop closer to 400F. Ever since it got warmer last week, though... I've had nothing but trouble.
Two hours ago, I loaded both stoves, usual mix of 1 year oak and poplar. Both stoves were running 350'ish prior to loading. Took both to 500F stove top at wide open throttle, then closed throttle to 50%, and took both stoves to 550F on the stove top. Engaged both cats, and each cat probe was reading 550 - 600F within a few minutes. Left both at half throttle a half hour, hoping the cat temps would climb a little higher, and they did, but both stayed below 700. Started incrementally lowering the air after 30 minutes in cat mode, and watched the cat temps fall back down to 400'ish on both stoves. Stalled!
Went back to bypass, took the stoves back up to 550F stove top on wide open throttle, and the single wall pipes were reading 675F - 700F on the exterior, 6" above the collar. Re-engaged, and both cat probes went to 750F. Left at half throttle another 10 minutes, and one went to 900F, while the other held in the 700's. Started lowering air, and one cat is holding in the 700's, whereas the other fell quickly back down to 500F. Last night I came downstairs to check the stove an hour after seeing something similar, and found the cat probe reading only 325F!
I'm tempted to go back to bypass again to get that one back up, but I've been up way too late three nights in a row dicking around with these stupid stoves, and I need some sleep. Both stoves were running much better than this when it was cold out.
