hi everyone , this site has been so helpful what is the clearance from ceiling to flue pipe??? i know that there should be more rise than run in the flue , but with my set up i can only get so close to the chimney making it hard to get the flue to pitch properly, unless i can go closer to the ceiling . right now i have 24 in. of clearance and my flue rises 28 in. and runs 40 in. into the inside of the chimney? i know that when i bought this house the sellers stated that this chimney did not draft well . ( by the way its a furnace located in the basement ) so i want to" help" the chimney as much as possible .. any ideas or is this pitch sufficient. the furnace seems to be drafting just well enough to be working , however my yard is a smoke screen , if i get the fire real hot then it does better but then i fly through wood. i plan on addressing the lining as well as height of chimney this spring , if these are the problems??? in the mean time its keeping us warm enough to survive .. first year burning wood and im loving it .. still experimenting and trying to learn as much as possible! any help or ideas greeatly appreciated! thanks joe
