Non-Combustibility
HardieBacker™ cement board is recognized for use in non-combustible construction in NER-405.
Surface Burning Characteristics
When tested in accordance with ASTM test method E-84:
Flame Spread
Fuel Contributed
Smoke Developed 0
0
5
Thermal Resistance
(Approximate value) 1/4'' thick: R:0.13
Again yo asked for supporting information and facts.. I Challange you to prove where one can Refute all known code bases and manufacture tested listings I want proof you asked me to provide so I'm asking you to support your point with proof
BTW I am Nationally Certified that means since all states adopted the international code I can be hired in all 50 states The mass qualifications are that I pass the national battery of testing which I will find and scan proof of passage in 1997
British Standards and Codes of Practice, particularly BS6461,
CP403 and BS5449, relating to the installation of solid fuel appliances.
http://www.jotuluk.com/content/products/ProductArticle____3619.aspx
Installation of a fireplace must be according to local codes and
regulations in each country.
All local regulations, including those which refer to national
and European standards, must be observed when installing the
product.
Both an installation manual with technical data and a manual
on general use and maintenance are enclosed with the product.
The installation can only be used after it has been inspected by a qualified inspector.
3.4 Chimneys and flue pipes
A chimney can be linked to the fireplace and flue approved
for solid fuel-fired fireplaces with a flue gas temperature as
specified in «2.0 Technical data».
The cross-section of the chimney must be at least equal to
the cross-section of the flue. Please use «2.0 Technical data» •
I may not have jusisdiction in UK but I still can read their installation manual to see the correct way to do it
