BeGreen said:
Agreed, for the record 6" -> 5" is a <17% reduction.
Let us know how it works out Jon. The 3CB is a nice little stove. I think you'll like it.
Your math is ok but you forgot to multiply the area by pie r squared. The diffencce in a crossectional are is app 19.5" for 5" pipe and 28.25" for 6" pipe. When I do the math that eequates to about 30%
I read the manual and cut and pasted the pertinent info concerning this situation Just wondering how else one interpets the question at hand without tested results.
My suggestion is to purchase a stove that will work with the currrent chimney. If the poster were not concerned he would not have asked the question The manual he has outlines the proper installation chimney needed. I think he asked the question to justify not being listing or code compliant. Fact insalling that stove in a 5" chimney does to things that are true it will not be code compliant and it will not be listing compliant. Anyone else that makes compromise suggestions please use acepted testing data or refference code language to support your arguement.
Tell someone that you scoffed the code and made it work is not scientific or really the intellegent aproach on a public forum. Telling me about a stove from way back yesteryear ,Lang that is noway indicitive of EPA phase II moderns stoves, again does not apply and is bad science, We all know how draft sensitive EPA stoves are and there is no comparison to 30 year old stoves and modern technology
Direct cut and past from the manual
Safety notice: If this solid fuel room heater is not properly installed, a house fire may result. For your
safety, follow the installation directions. Contact local building or fire officials about restrictions and installation inspection requirements in your area. Save these instructions for future reference. Page 2
Check Building Codes
When installing, operating and maintaining your Jøtul
F 3 woodstove, follow the guidelines presented in these
instructions, and make them available to anyone using or
servicing the stove.
Your city, town, county or province may require a building
permit to install a solid fuel burning appliance.
In the U.S., the National Fire Protection Association’s Code,
NFPA 211, Standards for Chimneys, Fireplaces, Vents and
Solid Fuel Burning Appliances, or similar regulations, may
apply to the installation of a solid fuel burning appliance in your area. Page 3
Stove pipe - chimney connector
The chimney connector is a single walled pipe used
to connect the stove to the chimney. For use with the
Jøtul F3 the chimney connector must be 6” in diameter,
with a minimum thickness of 24 gauge black steel. Page 4
The chimney size should not be less than the cross-
sectional area of the flue collar, and not more than three
times greater than the cross-sectional area of the flue
collar.
Page 6
Is there another set of standards that have exceptions that I am unaware of? Seems pretty clear cut what is required.
Even bettter who here has done the testing and can certify a 30% reduction reconized by UL I know I can't
I thought The Hearth was about getting it right,correct installation practices. It pains me to be sourounded by so many experts yahoos that have not one shread of documentation to back them up
And when I back it Up they are telling you I'm wrong?
The only correct answer is in your manual
