Question for PE owners. Specifically, I have a 2022 Alderlea T6. It has a newer style flame shield with a tab welded on that obstructs the flow to the flue considerably. I presume this was done to slow the evacuation of unburned gasses to make the secondary burn more efficient for the latest EPA regs. I have plenty of draught with 36 feet of chimney up through the centre of the house and plenty of vacuum under normal conditions. The problem arises when I go to add wood to an already flaming fire. Smoke enters the room even following the usual standard practices to avoid that. I made a deflector that has corrected the issue by 60% by driving the air flow down into the fire and deflecting the flame upwards to the gap in front of the secondary air baffle. Basically it replaces the action of the airwash in directing the flow of air when the door is opened, but has no impact when the door is closed. It helps a lot but I need to do more to correct this. Any smoke while reloading is unacceptable in the long term. There are two other issues with this stove contributing to the smoke. I think the biggest one is the huge restriction caused by the new style flame shield. The second which might not be an issue with less restriction, are the side rails that extend so far forward, that the flames 'walk' under the rails and right out the door when it is opened. As a matter of fact, even with the door closed and the airwash doing it's job, the flames walk the rails and roll off the glass at each side of the window. That's an easy fix, but one thing at a time. Question: When did PE start using this very restrictive heat shield with the 'wings'? Thanks, Derf
![[Hearth.com] Flame shield design change. When did it sprout 'wings'? [Hearth.com] Flame shield design change. When did it sprout 'wings'?](https://www.hearth.com/talk/data/attachments/318/318059-89c02f1a08bc05a15d673fb00a6a825c.jpg?hash=CI2od9gyNE)
![[Hearth.com] Flame shield design change. When did it sprout 'wings'? [Hearth.com] Flame shield design change. When did it sprout 'wings'?](https://www.hearth.com/talk/data/attachments/318/318060-b957b81ee602d685a7df5ff8261b6f68.jpg?hash=kwfWT8JBV1)
