Woah, horsie. I don't recall hearing, at least on this forum, of an insurance company requiring a sprinkler system in a residence with a wood furnace. If you want to do a sprinkler system, I applaud the safety mindset. That said, I wouldn't assume that plumber's opinion is a mandate.
It would only take me one occurrence of a puff of smoke causing the sprinkler to douse a perfectly good furnace, until I'd rip it back out.
I never said it was required, only that the insurance company has been made aware and approves of it. I'm sure he would get a discount on his insurance for having one.Woah, horsie. I don't recall hearing, at least on this forum, of an insurance company requiring a sprinkler system in a residence with a wood furnace. If you want to do a sprinkler system, I applaud the safety mindset. That said, I wouldn't assume that plumber's opinion is a mandate.
Ok, that is beyond OCD. someone may need to see a shrink. seriously, thats a lot of effort for heat.
What are the 2 ~4" ducts above the stove door?
You will very likely carry more flue temp for longer after you install that liner...chimney is probably cooling and losing draft.While the blower still kicks on about every 5mins or so, the stove (upper corner of the front door) will stay between 400-500 degrees (most likely a lot hotter inside the stove). However my flue temp will go down to 100 degrees with just about no smoke exiting out of the chimney. If I kick on the draft blower for a couple minutes, the flue temp will quickly jump to over 300 degrees, even climb to 400 degrees. I can only assume that this is how the stove functions.
2) When I woke up this morning, I had about 2-3" of unburned coals, some still hot red, however more just black and not hot. My old stove would burn almost everything down to a fine powder. Is this normal? Just assumed that the draft blower would force coals to burn to a dust.
3) Cleaning out, starting that next fire. In the morning, with the chunks of red and black coals, do you just toss wood on top and get the fire going again, or do you remove the black chunks?
4) Do you rake the coals so they fall through the draft grate?
Ever try pulling the coals to the front, then load on that?One thing I have started doing is using an ash shovel to bank the coals to both sides so when I load it the middle piece sits almost on the bottom of the fire box then a full layer above that. I can shut the door and it will last 4 hours like that if I'm home. It seams to burn much more even when banked. If not it will burn from the left to right as much as front to back.
An older furnace will not do any better on warmer days...it will only crap the chimney up if you try to run "low and slow"My biggest issue right now is it's 47 degrees out and unless I want it 80 in the house I can't burn over 40 degrees. I'm looking for an older non EPA model that has the air dial in the ash door. They are the same size and I think that could make it more useful on days like today.
My biggest issue right now is it's 47 degrees out and unless I want it 80 in the house I can't burn over 40 degrees. I'm looking for an older non EPA model that has the air dial in the ash door. They are the same size and I think that could make it more useful on days like today. The other option may be adding an air intake like secondary tubes that can be manually controlled without the inducer.
I can't keep a continuous fire going if it's consistently over 25-30°. Got down to 22° overnight last night and it's currently 75° in the house and I didn't have a fire going for most of the day yesterday. It's the nature of the beast with wood furnaces. Like bren mentioned above, the older smoke dragons will be even worse/less safe during the shoulder seasons. You need to make small/quick/hot fires. When it gets to be the shoulder season I do lighter main fire at night and then MAYBE another VERY small one either when I get home from work or in the morning. Talking about 15 lbs or so for the very small loads, enough for 2-3 hours of heat. I basically mainly heat the house at night and then let the inside temp coast down during the day. Then get home and either light the very small load or wait till bedtime and do just an light overnight load. It all depends, for me, on how warm it's going to be and if the sun will be shining, as we get tremendous solar gain due to the ~120 SF of southern exposure window area we have.
Using my Mark ii 25 manometer, the draft prior to installing the SS liner measured .08. Now readings jump between .08 to 1.04.
Not good! Get a CO detector immediately if you don't have one! A headache is one of the early signs of CO poisoning!Last, not sure why, but with this stove, the house has a much stronger camp fire/wood stove smell. Could also be that new stove burn off still. The smell kind of gives you a slight headache
