So - we have here a burner that burns and makes heat (fairly uncontrollably, it seems) way faster than it can exchange it. Can't slow the burn, can't up the exchange.
yep, what i was getting at when I mentioned inefficient comparing it to the old school ones.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
It's making heat too fast and almost impossible for it to exchange it.
Not sure how much that will gain you, overall. If it raises plenum temps, it will also raise flue temps.
I agree, as the larger the △T the more efficient the heat transfer should be as more heat should be stripped.
however....... (o boy, this may get long winded....again.
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
My wood furnace warm/cold air supply setup is definitely NOT a conventional setup. All I know though is that it heats this sieve of a house pretty damn well now and -MUCH- better than it did with the out-of-the-box conventional setup I had originally. In fact some of what I have done to achieve better results may actually go against conventional methods/thoughts/practices and may not even make sense as to how I'm seeing the results I'm seeing and may not even work for others.
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
I'm seeing them though, so that's all that matters.
Here's a prime example. When I first installed the furnace I did it according to standard procedure. Using an open staircase, I was taking the cold air directly off the cold concrete basement floor and heating it, using the low speed blower tap. Simple snap switch on/off blower. With the furnace on low I was seeing a △T of ~30° IIRC. Taking in 65° - 68° basement floor air and sending out ~95 - 100° supply air. I found out soon after installation I pretty much had no duct static pressure so that didn't help, as I was moving high volumes of air so fast through the air jacket it may not have had "time" to extract maximum heat. I was sending out high volumes of 95° air. The very first fall of burning I was pretty much burning 24/7 already and temps really were not all that cold yet. The furnace vitals were always fine, it was burning great, going on pilot for extended periods, good stack temps, great burn times, etc. I chalked it up to the house being that bad....which I knew it was seeing we averaged ~1,300 gallons of LP a year over a span of 5 or 6 years.
Fast forward to today.
I have been, for the past few years now, taking the warmer air off the basement ceiling AND also mixing some of the reclaimed hot radiant heat off the face of the Kuuma before it gets heated. In essence I'm taking in 80°-85° "cold air" and sending it through to be heated. I would probably see even lower stack temps if I was sending through cooler 70° basement "cold air", but it would not heat the house better. The warmer "cold air" directly resulted in warmer supply temps.
I also have my blower speed controlled and slowed WAY down. The slower the blower, the warmer the supply temps are once again. I have dramatically reduced the volume of air being passed through the air jacket and into the house, but dramatically increased the temp of it. I'm sending it maybe 70V when in the middle of a burn with the computer on low....it's cutting out at around 98° when the blower is only receiving 45V or so. My △T now, with the computer on low is still ~ 30°. Taking in 80°-85° air and sending it out 115°-118°. I have yet to have to take it off minimum burn this year. Guessing I will be seeing 125-130° max plenum temps on max burn......so a △T of around 40° - 45°. Seeing it's speed controlled, the warmer the supply temps are the more volume of air being supplied. It's a win-win.
So I'm sending out much lower volumes of warmer air and it's heating the house better in ALL weather, even below zero. The slower I slowed the blower down the warmer the supply temps, the better the results were. In the temps we have been seeing this winter so far (warmer than average), I'm still not able to keep a fire going 24/7 w/o over-heating the house. Seems I need 50+ HDD's before I can burn 24/7 consistently. A far cry from what I was seeing at first.
I also added an OAK to the BD as well as to the basement floor for makeup air. Was worried about it contributing to the "stack effect" of the house, but don't think it has. This has also seemed to have made a positive difference.
Anyway, the whole point of this rambling is everyone's house and setup is different. Don't be afraid to try different things. They may or may not work, but you won't know till you try them. I've tried things in the past which made things worse, but I wanted to try them.
I was also unsure about the OAK on the BD, but it seemed to work out just fine.
Brenndatomu's Skunk Works ????
yeah, pretty much!
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
