flynfrfun said:Here is the simple and cheap diverter I made. It is cut out of a 26 gauge sheet I got from HD. Cut it in a square and then bend it in the shape of the drop chute. I then bend the left side vertical to deflect some of the pellets to the right. That is all that is needed. You can adjust the amount of deflection to get the fire much more even. If you go too far it will kick some pellets out of the burn pot. Works great. To keep it from sliding down, I open up the "U" shape that goes behind the liner. You can then bend it to get it to slide in behind the liner, but it will spring back out enough so that it won't fall down. It may look a little rough, but it works so I haven't tried making a new one a little nicer. Besides you can barely see it when the stove is running anyways.
I like the diverter. Simple, easy, cheap and durable. Good idea, Fly. I was a little worried that you would damage the stove somehow if you made some radical change, like drilling holes and such. But the thing is so simple it really does not affect the structure of the stove whatsoever.
You should patent the little thing
