I don't think this is a good option. Putting a magnet fully over the secondary port is a poor solution. It defeats the clean burning of the stove and decreases efficiency by letting more unburnt gases go up the flue. Don't be a slave to the thermometer. Go more visually. If the fire is burning strongly, start closing down the primary air sooner say at 300F and a bit more aggressively. Consider burning larger splits to help slow down the fire a bit.
Try shutting down the air sooner and burning larger splits. You might also try to find the boost air supply to the stove if there is one and close that off with a magnet instead. This will take a hand mirror and a flashlight to examine the underside of the stove and locate air intake(s).
I switched from an Osburn Matrix (flush insert, 2.4? cu ft firebox) to the F55. Whereas as the Matrix would be good down to the low 30's, the F55 is good into the mid 20's maybe? Just a guess really. It definitely puts out a bit more heat, but I don't think the difference is dramatic. More noticeable is not having the fan run all the time, but hard to say if it's worth the $ to upgrade just for that. I really liked the Matrix, got similar burn times and preferred its looks to the F55. I suspect one day I'll install a wood boiler and go back to it.I have been looking at changing from an Insert to the F55 and was curious if others with this stove had done the same. Currently burn with a Jotul Rockland 550 (3 cubic foot firebox) rated at 1,800 square feet and 65,000 btu’s.
It seems the F55 is super easy to use, puts out a ton of heat and nearly everybody is incredibly pleased with the stove.
Again interested if others had switched from an Insert to this particular wood stove and if they could offer any feedback. I am not disappointed with the Rockland (it does what it is rated to do) but it really struggles in my center chimney 2,500 square foot home when the temps get below 30.
That's good news. It looks like there is some secondary air coming in. That is also good, don't block it off entirely. Split a good portion of the next batch of wood to 6"-8" splits and that will also slow down the fire and increase burn times.Just did another full load, closed down early and it topped out at 550 or so. I guess I was letting it get to hot before closing down.
but if I leave the air fully open, the flue will easily shoot above 550 and head into the red
What type of flue temperature gauge are you using? I don't "hit the red" until 900 degrees, which I'm completely comfortable with, as my Metalbestos Class A chimney is rated above that, and my Selkirk double-wall stove pipe is rated for 1000 degrees.
Should I keep doing what im doing in regards to the flue temp? The max flue temp this weekend was near 600 on the thermometer, which is located just before the 90* turn into my chimney - roughly 18" above the stove. It hit this temp during a small reload when I left the air open a little too much. It smelled a little like the paint was curing, but as soon as I turned the air down, the flue temp leveled out.
Are those internal temps?
I assume that is an outside flue thermometer on a single wall pipe? Internal temp will be 1.5x to 2x as much which brings you at or slightly above the recommended max of 900 F. For a short time, probably no harm was done. Still, I would try to cut down the air a bit sooner/more aggressively.
I know this might be getting off topic but can someone take a measurement for me? Anyone who has a rear vent into a Tee what is the height of the tee where it connects to the liner.
Thank you
