Its later
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Where are the flippen details???
Platience young glasshawper, platience.
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
Jr. needed his baba...
Another load of Hickory and oak at 6:10 AM, so we will see how she does on a 10 hour load today. Supposed to be a high in the mid 20s...
Well, when I got home from work tstat said 71*, this was at 4:30, so almost 10.5 hrs, high of 25* out today. Not too bad I guess, still had good coals for an easy relight. Threw in some more Hickory and Oak...it took a while, but it is back up to 72* in here as of about 8:30-9:00. I really don't like that I can only raise the house temp 1, maybe 2* during the hottest part of the burn, seems like it should do more...
The recent changes were: adding the third duct, and then running it almost wide open
A new air filter (which lowered RSP)
And last but far from least, I lowered the temp controller to close the damper at 350* and reopen at 250*, which has been working out really well. 350 is plenty of temp to fire off the secondarys and the temp will usually hold around 300 for a couple hours. A couple hours more before flue temp drops to the point where the controller will let the tstat re-open the damper. So we are 4 hours in now. 2 or 3 hours more of heating with the tstat cycling the damper open/close (so the high point of the heating curve is past) So we are 6 or 7 hours in now and it is likely that the damper is just staying open all the time now, which gives ok heat (not great) from burning down the coals.
At this point I think I am pushing this thing about as hard as I can without just running damper open all the time...unless adding a plenum ends up making a big difference, I dunno...
Before somebody suggests that I am not running it hot enough...even when I had the temp controller set to shut down at 550*, once the damper closes the temp always wants to settle back down to that 3-350 range anyways, and fairly quickly, so...
This is even with -.07" draft last night, so not low draft, and my wood is SUPER dry 3 year CSS Oak and Hickory, so not wet wood...
Also (gettin past my bedtime here...) I installed a turbulator in the center HE tube. If you want to know what that is, search that term in the boiler room, there has been lots of talk about them. Basically it causes the flue gasses to be turbulent and have to contact the walls of the HE tube instead of the majority of the flue gas volume just blasting down the center of the tube without much contact time with the tube walls. It did seem to drop my flue temps some...
I'll get pics of this thing the next time I open the cleanout door. Nothing fancy...quicky homemade deal...some good ole redneck injoonearin...
