so decided totake apart the stove for its big cleaning due to wife saying its getting cold up here at night ( LOL ) so I break it down, remove brick panels to vacuum and clean chimney ect......
pull the heat exchanger scraper, pretty dirty.... vacuum up..... scraped again and didnt feel right..... get the light and wipe it down inside and BAM......
the area at the top of the fire box is dented... dented nicely on both sides and really hard to notice and looks factory. I am use to my lennox montage that has a small pull to scrape the heat exchanger ) get a big screw drive and pry it out on both sides and clean it up. then i chip away at the solidified ash nuggets in there for the next half hour......
finally.... brushed them out, cleaned, and now the heat exchanger scraper can be pulled all the way out. now the stove is fully cleaned and ready to go. hopefully LOL
*** had no idea the top was dented only allowing the scraper to go 4 inches instead of 10 inches. herd to tell when looking as not a lot of opening to see. Hopefully this will solve the overheating issue as it makes sense seeing i was only cleaning 40% of the heat exchanger. Man I had No idea that the scraper was stuck and dented..... teach me to buy a demo stove......
i will update again when running it....
thanks
steve
thanks
steve
