Enviro Omega Install Question
deadeye316
101
Amsterdam, ny
I am getting a Enviro Omega installed this wensday. This is my before pick. Question I have is they measured it out and they said putting in the corner is fine. I heard from acouple people that its not good for it to be by the window. Anyone see a problem in this being installed in the corner?
  • [Hearth.com] Enviro Omega Install Question
The corner is fine
If you get rid of the long curtins.
I would not put it there if I was the installer unless you put Sorter blinds in
My Omaga is in the corner.
http://www.hearthtools.com/pellet/enviro/omegared.jpg
Are you exhausting straight out the wall? If so I wouldnt exhaust out the wall where the window is close to the corner. Going out the other you'll have to consider the outlets.
I guess I would put it sort of centered between the corner and the window on the left. Seems with it cornered it might ubstruck the window.
How about where the nice chair is sitting?
Is either wall the front of your house? If so, think about the aesthetics of the pipe on the outside.
That's a pretty cool stove. I look foward to hearing about your experience with it.
I'd center it between the corner and the window on the longer section of wall. At least leave yourself enough room between the corner wall and the side of the stove to get in there for cleaning if possible.
Yes, the vent pipe is UGLY! As much as I hate to put a hole in the roof I'll be running ours up past the eve this summer just to get that ugly hood above the roof line. It looks like some kind of Star Wars creature sticking out of the wall. :ohh:
The only problems I've encountered with a corner installation is it makes it more difficult to put the pellets in the hopper and to get to the control panel which is located on the hopper. You might consider putting yours on the wall to the left as others have suggested.
I dont think he is going to direct vent.
I HOPE NOT!
here is the thread with photos of my corner installation.
https://www.hearth.com/talk/threads/12497/#139379
Not going direct vent. If that backed into the house my wife would kill me. We are going up atleast 3-5 feet. The vent is going on the left side of the picture. So if you are facing the house it would be on the right. The only issue i have if i go out then up is the outlets where the pipe would go. Also It does get windy and damage the pipe if more exposed.
Can you post a photo of the Out side corner of the house
Looking at the house
This is all i have from the front i will take one from the side tomorrow. That pic is from a year ago
one reason i can see going up and out is the wind maybe. Will it hurt or mark my siding is there anything i should make sure they do and dont do at the time of the install.
If you are worried bout the wind then spend the extra money and have it run all the way up the side of the house.
If you dont have them put a min of 10 feet then a 90 then about 18" out then the horizontal cap
the 10 feet will trap most of the soot
