Burned properly they burn a lot cleaner than cord wood. If I lived in an urban area this is all I would burn.
IMHO, they are called wood stoves, and tested as so. They are not called Bio-Brick Stoves!.
Hi,
My local stove shop and reps from both Travis Industries (Lopi, Avalon) and Pacific Energy have all told me that using any compressed wood bricks/logs will void my new stove warranty.
My local stove shop installer told me that burning one compressed log/block is ok but anymore than that will over fire the stove. He said that compressed logs burn fine in fireplaces and inserts but not wood stoves.
I am about to get a Lopi Endeavor installed (my first wood stove) and am having trouble getting seasoned wood. I thought I fixed the problem when I ordered two pallets of Envi blocks. Now I am thinking of canceling the order as not to void the 7 year Lopi warranty.
There are many different types/quality of compressed wood products. Surely some of them must burn appropriately in a Lopi or PE stoves. Should I cancel my Envi block order? I have until tomorrow morning to cancel the order!!
State side we have a real problem between compressed wood logs/blocks and the stove mfgs. Which makes for a very poor investment situation from a business standpoint for domestic consumption until the stove mfgs get on board. Europe is not so backward by necessity due to the lack of raw material.
Look there is plenty of seasoned wood to be found about now in Concord and Wilmington,Ma.Google firewood in those two towns and talk to the sellers.Try Marshall farms.He has about a 100 cords of seasoned firewood.He says he'll sell it all so don't wait.The number is 603-738-9429.He's in Concord Ma.
Yep, to me that distinction between Envi-blocks and wood does not make any sense. Does it also void the warranty if someone stuffs his stoves with 2x4s (made of pine!)? Or well-dried kiln wood? What happens with members that live in Texas or Arizona and get their wood down to 8% moisture content? If a company wants to exclude warranty claims because of overfiring they should include a stove thermometer with an exact spot to put it and a temperature that should not be exceeded. Imagine car manufacturers would deliver their cars without a speedometer. I don't see the difference here.
I fully agree with isipwater in that over firing is over firing. While Kuma does not specifically mention compressed wood, there is a warranty exclusion for improper fuel (coal, etc.) and over firing in general. I have personally burned compressed logs in my own Kuma at home, up to 9 North Idaho Energy Logs at one time. I can also glow the top of my stove every time I use it with cord wood if I don't tend it properly.
While US manufacturers could be more accepting of compressed wood, and probably will be in the near future, there are many many other ways to overheat your stove. In defense of manufacturers, there has to be some responsibility on the user to understand the basic limits of the product. Manufacturers have just found it easier to give the black and white, rather than detail the grey. I appreciate the analogy given by Grisu with the car and speedometer but even that is not that black and white. With no understanding of the limits of 1st gear, I could damage the car without even reaching half of it's speedometer limit.
To relate to stoves, how can we relay all of the conditions in which a stove is being over fired? I frequently heat my own stove top to 800 degrees before shutting the air control down. It usually takes 10-20 minutes to reach that after re-fueling, depending on the coal bed. So, if 800 degrees is OK, is 825 over fired, and is the stove warranty void if it reaches 825 for only a few minutes? If 825 is the limit and 800 is safe, how long is 800 safe for? What becomes the safe temperature for 100% duty where you feed the stove like it's running a steam engine?
With the Kuma warranty not specifically excluding compressed logs, one could argue that a stove damaged by the same is our own fault because we didn't say not to use them.
Jason - I agree with everything you said. That being said, why is there not a clear cut max temp listed in most operators manuals (this is not in any way directed at Kuma). This is one of the most frequent operational questions we answer on hearthdotcom. Trying to guess the color of the glow is a horrible way to answer a question (and is already at overfire temps as far as I am concerned). In an industry where it is easier to just list black and white answers - why is there no answer to an oft asked question?
But to digress - yes, an overfire is an overfire - it really doesn't matter how it got there.
(I am not really trying to put you on the spot, just hoping that someone in the industry can give a non-political answer to this question).
