Well sweep came today, boy I'm in the wrong line of work , $200 for 10 min of work. I think my draw problem was an extra piece of stove pipe pushed all the way to the backside of the thimble. Didn't know it was there.Seems to draw good , no smoke coming into the basement when I open the door, fire gets going really good, but still wants to go out when I shut the door! Found out it's an 8"x 8" chimney . Sweep said it should be more than good enough. Am I not getting it hot enough before closing the door?
37 outside , 85 in my basement and 75 upstairs on main floor and 72 upstairs . Door closed air closed to about half . Awesome lightshow, but now I'm going through wood like crazy, just as bad as the old smoke dragon!! Now what am I doing wrong? Lol
37 outside , 85 in my basement and 75 upstairs on main floor and 72 upstairs . Door closed air closed to about half . Now what am I doing wrong? Lol
Think I've found the culprit, WOOD!
Threw some split 2x4's in with my burch that was already burning closed the door and said F' it . Took a shower went back to check
It one last time . Door chit air almost completely closed , 2x4's burning bright, other logs nothing! Wow ! So wood has to be drier than 20%. Always thought that was good. Not for the good ol EPA I guess! Don't know where I'll find any drier! Saga continues!
I agree 100% with Kenny. 20% really isn't that great for EPA stoves. ESPECIALLY when trying to get a fire going. I have 3 partitions of wood that are 12-13%, 15-17%, and 19-21%. The wood that is 12-13% is my Cadillac wood by far. Almost instant ignition and heat. Burns hot and almost entirely on its own oxygen. I can have my primary air intake just about completely shut, while maintaining 6-7 hour burn times, at 550-650* stove temperatures. My 19-21% wood does burn fine, but only after about an hour of ramping up, and boiling out some of that remaining moisture (non-visible). Much more energy wasted in the first phase of burning.
My 12-13% wood is indeed 12-13%. I have about an 1/4 cord that has been stored in a closet for over 3 years in the home we purchased last year. It is indeed BONE dry. It weighs almost nothing and will register 11-14% on the meter after a split through the center . I throw out the low and high reading. We also keep the house climate controlled at 50% RH through out the summer, and will be 35-40% during winter. I am far from bragging, and I am data, and experimental compulsive. This is not your typical seasoned wood that sits outside year after year. Your entitled to your disbelief.You don't have 12% MC wood in New Hampshire. That might be what your MM reads, but it isn't that low. I know everyone here likes to brag about wood moisture content like it's willie size, but you can always tell whose full of it, and who sits back with the quiet confidence that comes from knowing you're both prepared and not a liar.
It gives you an idea when you can get max efficiency from your fuel. Is it critical? Not at all, but it does help with guessing games when not being able to burn that "Perfectly seasoned" wood. (Which MANY people do not even burn wood remotely dry enough).Not to thread jack, but do you all find a MM to be a critical tool to assist in how and what you burn throughout the season?
