That's kinda strange but as long as both our stoves are working good I guess.
I am interested in getting an ip as well. How is it doing in this miserable cold we are currently having?
HOLY cow. I just looked them up. I am selling my castile and getting one.
Its a taller unit...... i didnt realize how high when i bought it and the heat exchanger (on mine anyway) needs to be "tapped" on semi regular.basis BUT......the thing heats like a beast is very efficient and heats my house. Its a great unit!
I can't find this measurement online..
How far from the floor is the flu exit and oak ?
Also, this will be installed infront of a fireplace replacing a wood stove. Also curious if an OAK can be routed through the floor.. Unfortunately I don't have an outside wall to work with. Are you running an OAK on yours?
Thanks!
Mine has been doing well........ However it was running with a lazy flame and filling the burn pot with pellets..... turns out the heat exchanger can get "clogged"
The fix?
Take off the fake brick and bang the living #@#&^&^ out of it with a "framing hammer" . That's according to englander too.
on a side note it has basically heated my house which is a two story split level ranch app 2100sf.
(I edited this to read what I typed originally not what that darn auto correct did on my phone.)
The stove will be replacing a current wood stove.
The chimney is lined with a 6 inch stainless rigid liner. I plan to adapt the pellet stove to this liner using the duravent adapter.
The stove is located in front of the fireplace, in the center of the room. I don't really have anywhere to go with an OAK except up, or down. Up, would be impossible...
It's alittle bit more tempermental than the 25 series i have had but you are rewarded with alot more heat... last year was one of the colder winters i have seen too.Long term bump. How has the 25-IP fared and are you still happy with it?
