eurekkkkaaa i got it working like a charm. i found some window expafoam seal that my buddy sells for his company... its like expandafoam but its more weather sturdy... anyway it dries in 5 minutes. i slapped a bead around the outside of the door seal and closed and rested a few bricks against it and then sealed the door lip all the way around to make sure it was air tight. i got the fire going again using some 2 by 4 chops and some cut pieces of the fire wood. i get it going good by gradually closing the door. i finally get it closed and to my surprise the fire stayed lit ... i left the room and came back 10 minutes later thinkking it would chit the bed again but it was going even hotter... so said alrighty.... lemme try to close the air supply... to my surprise i heard wind howling in my stove pipe told me that this thing was air tight and i had that tight draft i was missing.... the fire at the bottom of the coals disappeared and the entire top of the rods was passing flames through every hole... i gave it some more air and set it at a good rate .... i had my knob slid a little farther out than the ash lip...
thank you for the input guys...
anyone out there that has one of these stoves with a clean out door you need to expandafoam it shut or something .... it makes a huuuuge difference especially me with a larger sized flue
thanks again !!
thanks again !!
