tmyers said:OK now we have a new development. The stove is now making a noise. Its kind of a whistling/humming/whirling noise? I sure hope the combustion blower is not going!
Still having the overflow problem with the pot if I set the feed rate higher than 3. Current bottom button settings are 3 9 1. It just is not throwing heat as it should. It was 28F outside today and the darn thing was set on 3 all day. At that rate it should be hotter than heck in my house! I guess I will need to make a phone call to tech support today after work. sigh!
tmyers said:So my control board should be on "C" ? I can check that tonight when I shut down to clean. Thanks will post in a bit with what mode it is on. Sigh..........
It makes no difference what speed the room fan is on. The noise comes and goes randomly.
tmyers said:I added a recording of the sound to my previous post.Let me know what ya think.
burnit said:I know what the feed rate setting and blower setting are but what are the "bottom 3 settings" that I've seen people talk about here. How do I check what mine are set at? How do I adjust them? How do they work?
tmyers said:All I can say is WOW! What a difference! I had no idea this stove could throw so much heat! It must have been on mode "A" since I got it.
Thanks smokeythebear for the idea to check it. Just in time too it is -14F here tonight. I have only heard it make the "noise" once since I fired it back up about 7-8 hours ago. I am keeping my fingers crossed.
Thanks everyone for your help!
Tonya
burnit said:Smokey, do you have more details on how to change the setting. I plug the unit in hold the blower up and down buttons. What's strange is that the reading appears on the feed rate setting. Mine was reset to a then I use the feed rate up or down to change the setting to c. Anything after that to lock the c in or just hit the on button to turn it on?
SmokeyTheBear said:burnit said:Smokey, do you have more details on how to change the setting. I plug the unit in hold the blower up and down buttons. What's strange is that the reading appears on the feed rate setting. Mine was reset to a then I use the feed rate up or down to change the setting to c. Anything after that to lock the c in or just hit the on button to turn it on?
I don't know, I suspect that when you change it and hit on it gets locked then. I haven't gotten my paws on one to play with. I have looked several England units over looking for things that could cause problems with air flows.
