Energy king 385ek not heating whole house
I normally put the level on the vertical face to level it vertically. Assuming what you did is fine though..?
With that high of draft, you may have to add weight to the weight on the flap. I had to add a thick washer or two to mine to get it to pull the draft down enough.
To me level side to side (pivot pin exactly at 3 and 9 o'clock) is more important than the vertical of the tee being dead nuts vertical
I can fix it tomroorw def off a bit
  • [Hearth.com] Energy king 385ek not heating whole house
Read three articles and all different options any suggestions on my limit switch settings
right now 115/150/200
That 200 is fine...the other 2 maybe 110 off/140 on? Dunno...probably just need to play around with it and see what works well...
moved it to that settings
the whole wood stove is acting different now
-stove is actually getting hot outside is about 500 degrees with laser thermometer
-Stove pipe isn’t bad should be alittle hotter temp wise with magnetic temp guage
hot air is actually blowing thru the vents
only concern right now is stove getting close to 500 degree may be fine but haven’t seen it actually get that hot
also nanometer is almost perfect
This is where I think I should adjust the dampener to allow the pipe to get hotter? Maybe bring it up to .05?
Just under 250
Perfect...250* (242) externally means almost 500* internally...and that's plenty!
Oh...wait, that's a probe type themometer? If so then yeah...a little low.
You could try to bump up to -.05"...or is there some sort of damper adjustment on the furnace?
it’s a single wall pipe so I am using the condae magnetic pipe thermometer
You might go around the pipe and find out which side shows the hottest, then use that spot...I would guess more toward the furnace side of the pipe, and maybe a little toward the high side (left when you are looking at the back of the furnace) will be the hotspot.
also nanometer is almost perfectView attachment 274165
I'm not a furnace guy but I wouldn't have expected the furnace to get much hotter by getting draft under control? Might have to check out static pressures etc in your duct system? Almost sounds like you need more air moving through it now. I'll duck out again now.
Reactions: sloeffle
I can do that with going down to merv 4 filters
I was unhappy with my 1" filter setup that came with my Max Caddy so I removed the filter and sealed the OE filter housing. I then added a GeneralAir 20X25X5 housing in my return and run MERV 11 filters in it. It's a much better setup and doesn't get dirty so quickly. Just an option if you find your 1" filters are being replaced too often...
You already dropped from 11 to what, 6?
So what's your findings after running a load or 2 through 'er?
Seems way better!! The soon to be baby’s room was 67 while the house was 70 that’s the best it’s been yet!!! So maybe 4 will get it 1 degree more
we are gonna get blackouts curtains for that room it has a lot of windows
Reactions: sloeffle
