end of the adventure
stovexxx
692
IT
just as the title says, an adventure ends, I've tried everything, it seems impossible, despite the draft of the stove, and the air exchange, to have an impeccable air quality, I should accept 6-10 ppm carbon monoxide (without cooking) I think that the heat, the fire, expands, and somehow, comes out in small doses from the joints of jotul, maybe a steel stove is better because it has fewer joints, anyway. Maybe I'll sell this piece of cast iron or put a fire effect lamp inside, with some pieces of wood! Thanks for all the support provided.
Reactions: ctreitzell
A welded steel body stove can have only one seal to maintain, the door gasket. Our CO meter doesn't budge when the stove is burning.
Reactions: stovexxx
I was uninstalling the chimney and...
the penultimate pipe (each is 1 meter) was literally disconnected, compared to the last pipe, the one that comes out of the roof (the pipes of my chimney travel inside a chimney, inside the masonry of the house) so the pipe were misaligned,compared to the last meter
so I had an air draft, a leak and I had smoke that did not come out completely, directly;
however I did not smell smoke but I noticed something strange (carbon monoxide)
I'm starting to trust wood stove again👍
Nice (well, not so nice but good find)!
I hope this solves the problem.
It's good that the investigation continues. If some of the fumes were back-siphoning inside the outer pipe, that might explain the high CO readings. Let us know if they CO drops a lot, like to 0.
Excellent news! Well-done indeed!
