Vtgent49 said:
I appreciate the dabate here. But, shouldn't we have a plan for the 100 year Ice storm? I've seen the 4 day power loss twice in 29 years here in VT.
My present system can be modified to run well on thermosiphon. I just crank open one 4 way valve manually, then the whole thing takes off. I do have to manage the fire so that I don't overheat, but that's a normal task it seems to me. I have a second 4 way valve for the second floor that I could open, but I hardly ever circulate to that floor anyway.
No offense to the Nossil fans, of which I am one, but there may be a point where all this control/analysis is counterproductive. I'm kinda a do-it-myself/prefer the 1880's method/elimate carbon etc by getting back to basics kind of guy.
All of these old wood/coal boilers ran for a century without electricity.
Could be another thread, sorry.
Al
For me, there's a constant tension between simplicity and technology. My goal is to refine the technology to the point where it's as close to invisible as possible. Doesn't mean that it's simple, just that it appears simple in operation. Some of the places where I feel as though I've approached that goal:
1) My domestic hot water gets heat from four sources:
- Preheat coil in storage
- Solar
- Wood boiler
- Oil
All those sources contribute their portion automatically, and hot water is always available - no human interaction is needed.
2) Wood boiler operation is as simple as it can be: Look at the control panel. If it says 'build a fire', then do so. If it says 'add wood', then do so. Otherwise, have a beer.
3) Heat source priority is completely automatic. If the wood boiler is active, then heat comes from there. If it's not and the storage is hot, then heat comes from storage. If the wood boiler and storage are both cold, then the thermostats set back automatically and heat (if needed) comes from the oil boiler.
I get a lot of enjoyment from tinkering, so I spend a lot more time and effort than necessary on refinements. Really, all I
have to do is build a fire now and then. This whole deal with battery backup is so that I can avoid having to put down my beer just because the power went out.
I do have a generator for extended power failures.
Despite my boundless appreciation for the good old days, I'm very happy that I can keep a big house comfortable with four cords of wood, no oil, and virtually no smoke. Technology really does make things better once we understand it. I get my kicks out of the 'understanding' part of the process.
Even the 1800s' axe head carries in it a vast science of metallurgy which is invisible (and simple) to the user. Big improvement on the flint axe, though ;-)
