On numerous occasions I've found that long after the fire has burned out in the EKO the primary circulator for the boiler is still running because the return water temp coming from storage is above the set point (150°). This is concerns me because it seems like this method of operation is destratifying my storage. The only way I can figure to combat this is to make a fire and return after it has gone out and manually shut off the controller on the EKO so that the primary circulator stops running.
What do you guys think, is this a valid concern?
