Have you noticed more buildup in the stovepipe connecting the boiler to the chimney than the chimney itself? I've only been running my setup for about 6 weeks and i've noticed creosote buildup in the boiler itself and in the connecting stovepipe but the chimney seems to be clean other than the fine film of glassy black creosote like you mentioned.I've been heating with wood for 20+ years and am still learning the art of properly firing a wood burner. Our is a one story house with the boiler in the basement. The boiler connects into a massive brick chimney in the center of the house with three tile lined flues. We have never had a chimney fire. We burn both pine and hardwoods that have been seasoned at leasst one year, but generally two years. I do have the chimney cleaned every year prior to heating season. Each cleaning produces about five pounds of fluffy creosote that is knocked of the flue tile by the cleaning brush. After cleaning there remains a coating of hard, somewhat shiny black tar like coating on the flue tiles.
That we have never experienced a chimney fire is partially good luck, because I know now that there were times when I was seriously overfiring the boiler and undoubtedly dumping dangerously hot exhaust gasses into the flue. About 10 years ago I started using a flue gas thermometer to monitor temperature in the flue and have come to realize that this is the most valuable indicator I have for monitoring and controlling the wood burner. There has always been a barometric draft damper in the flue, but I found this was not sufficient to control the firing rate and flue gas temperature, so I have added a manual draft damper which I tweak as needed to keep the maximum flue gas temperature below 800 degrees.
A couple years ago I added heat storage, with which I was able to reduce the percentage of time the boiler was idling nearly to zero, but to my suprise I am still getting about the same amount of creosote each year when the chimney is cleaned. What I did find is much less creosote accumulation in the boiler's fire tubes.
Based on my experience I believe the amount of creosote deposited in the chimney is mostly related to the amount of wood burned, and if I clean the chimney regularly and control flue gas temperature I will not experience a chimney fire.
I cant be sure but usually stuff described as "fluffy creosote" Is burnt creosote and is evidence of a chimney fire. When was the last time you had your flue scanned and professionally inspected? And if you are getting 5 pounds of it every year with glaze left in the chimney it sounds like you need to clean more often and change your burning practices.Each cleaning produces about five pounds of fluffy creosote that is knocked of the flue tile by the cleaning brush. After cleaning there remains a coating of hard, somewhat shiny black tar like coating on the flue tiles.
I can't comment on the thickness of accumulated creosote on the chimney wall as I have not looked down the chimney just before the chimney sweep does his thing with the brushes. I do remove the connecting stove pipe and clean it every year and routinely find about a 1/2" layer of fluffy creosote and ash clinging to the inner surface of the pipe (my stove pipe is 6" diameter). Next time I will look down the chimney before it is cleaned. What I can say for certain is that the tar & creosote buildup on the inside of the boiler (in the firebox) is minimal and has vastly decreased since I added heat storage.Have you noticed more buildup in the stovepipe connecting the boiler to the chimney than the chimney itself? I've only been running my setup for about 6 weeks and i've noticed creosote buildup in the boiler itself and in the connecting stovepipe but the chimney seems to be clean other than the fine film of glassy black creosote like you mentioned.
I really don't know what the significance of fluffy creosote is. Maybe some others can comment on that. I have not had my flue scanned, however the gentleman who cleans my chimney is a professional chimney sweep. He does a visual inspection of the chimney as part of his service and tells me when he sees something that needs attention. I estimate that I burn about five cords of wood per year. Should I be conceerned that this produces five pounds of creosote?I cant be sure but usually stuff described as "fluffy creosote" Is burnt creosote and is evidence of a chimney fire. When was the last time you had your flue scanned and professionally inspected? And if you are getting 5 pounds of it every year with glaze left in the chimney it sounds like you need to clean more often and change your burning practices.
Fluffy creosote doesn't mean chimney fire. A chimney fire leaves nothing behind if it burns out on its own accord.I cant be sure but usually stuff described as "fluffy creosote" Is burnt creosote and is evidence of a chimney fire. When was the last time you had your flue scanned and professionally inspected? And if you are getting 5 pounds of it every year with glaze left in the chimney it sounds like you need to clean more often and change your burning practices.
No not necessarily many times it leaves behind a fluffy expanded creosote. There are times that it burns clean but that is actually pretty rare and only comes from very intense fires which are much less common that the slower ones that leave behind the expanded fluffy stuff. Now without seeing the dirt that the poster was talking about i cant say but fluffy is a common description of itFluffy creosote doesn't mean chimney fire. A chimney fire leaves nothing behind if it burns out on its own accord.
Thats interesting. I have no clue as to why my wood burner should be making so much more creosote on less wood burned. I do have a barometric draft damper in the flue and it is usually partially open when I am burning. I'll bring that up with my chimney sweep next summer and get his take on the amount of creosote my wood burner is producing.Yes i burn about 6 cords and make about a quarter gallon on a 40 year old stove
I have experienced the runny tar-like goo running down and out the primary air draft door beneath the grate. It became a problem when the boiler was idleing a lot. Now that I have heat storage, the boiler rarely idles and I have not had to deal with the goo. I think this tarry liquid comes from liquid and vapors emitted from wood baking in the firebox that condense on walls of the boiler when the boiler is idleing and it is not hot enough to burn them. If you load the firebox very full, the wood near the top of the firebox isn't very hot and may be emitting vapors that create the tarry liquid.I think I need to get a moisture meter and check my wood for moisture content. I know it has been down and cut and split since before last winter so it is reasonably dry. The chimney doesn't seem bad and the connecting stovepipe has some buildup but the inside of the boiler seems to have a lot of creosote buildup. For my boiler it doesn't seem that bad to me because I have heard stories of people with my boiler that get large amounts of creosote running out the doors like thick tar and making a complete mess. I don't have that problem but i do notice once in awhile the door sticks a little and i see a spot where some creosote ran down the door and stuck the door to the frame. I also notice that sometimes there is creosote running down the door frame after a burn. Sometimes I see it even if I had a hot burn. It is soft a gooey and I try to scrape as much of it off with a putty knife as I can. Sometimes I can even see a couple of runs on the wall of the firebox inside the boiler. I try to use the Kwik-Shot sticks twice a week as it recommends to dry out the creosote. I do notice after using those a layer of creosote drys and peels off the next I have a really hot burn.
I've thought about getting a moisture level meter as well. Here in Western Pennsylvania we have a lot of humid days that makes air drying wood challenging.
Interesting. Currently the draft on my loading door is open about the width of two fingers, but it hasn't always been that way. This past summer I did some major maintenance on the boiler which included freeing up that draft which had been stuck closed for some time.This small draft is supposed to allow air in to mix with the flue gasses and burn them when they mix while getting sucked back through the bed of coals. I have noticed that makes a huge difference. If this draft is open I don't get too much buildup. If this little draft is closed the amount of buildup is unbelievable. It runs down the inside of the door and is dripping off the top and walls of the firebox.
I agree with what most are saying. I have a stainless liner inside the normal liner with insulation poured all around it. I also have fiber blanket on the stove pipe on its way to the chimney in the wall in my boiler room to keep as much heat as possible in the stove pipe.
The other thing i do is check my wood and burn what shows to be the lowest % moisture. The thing that i think helps me a lot too is that i don't have room in the house for hot water storage so i turn down the heat to 50F when i go to work and when i get home i fire up the wood boiler and it runs wide open (about 500-550F) with a IR for about 1.5-2 hours to bring the house back up to temp after that the amount of wood i put in the boiler is much less. I have a harmon SF-260 that i bought used and i am making it work. I also don't use the boiler much unless the outside temp is below 25F or so. If it is warmer then that i burn NG.
