Carl, just my 2 cents again. Its only Dec 2nd, you are in for a long winter if you have to light a fire every 2 to3 hours with wood split smaller than 4'" You need to let it go out, pull the pipe, and see how bad that 8" flue really is.  Do you have a chimney brush? See how hard it is to push up  & down the flue - A really bad chimney fire will crack that chimney & spread to the framing of the house.  Small hot fires every  few hours just  let the chimney cool off in between them....starting the problem all over.  Do you have the oil  furnace in that flue too?  You said before it used to be?  If not, why is there a baro. damper?  If you were putting an air tite stove in that flue [basically what your wood boiler is] you wouldn't have a baro. damper.  Someone else correct me, but I think it cuts down on draft through the fire, lets cold air up the chimney, not helping your problem.  That pipe thermometer should be a lot hotter right behind the unit.  As you get farther up the chimney, it drops like a rock. I wish it was easy, but I know what I went through for 16 years, I don't believe there is an easy "fix" for what you have.
		 I think he said it had to be a beer can?
