yeah, no excuse. I have the outdoor version so I have to remove the entire back of the skin, the entire flue, before I even get to the boiler. From the looks of things I think ill have to remove the roof also if I need a 3 foot brush rod to clean them out. Definitely a pain. Good tip about the clevis pins, I hear the bolts can be slow to access/remove.
But back to scraper, from what I read here, I fully expect that a scraper is the only way to go, yet nobody here has bought one? I'd be interested in your scraper build, but it likely involves welding and I haven't learned about welding yet.
also you say the 2" brush was too small so I want to clarify the tube size on the econoburn. Is it 2 inches?
I will check my brushes.
I would see if you can do it with a roof removal. With the indoor they show removal of the flue and back plate. I have found that if the seal is not leaking you don't have to remove it. I tie the turbulator handle in the up position. With a 9/16 wrench and socket you can then remove 2 bolts for the turbulator linkage, put handle in the down position and pull the turbulator assembly out.
The clevis pins should make it even easier because I won't have to use wrenches to get them out. Just 2 nuts on the top cover.
gg
