Earth stove 3000
Mattones
1
Ontario
Hello everyone I am new to the forum and was told about this forum through another online forum
I bought a 100+ year old house two years ago which runs off propane. It can get pricey as we all know. The house is chilly. This past summer I did a lot of work to help keep the heat In. The previous owner had a stove in the basement and took it with him. I recently picked up a free Earth Stove 3000 series. It looks to be in great shape. Ill post pictures for you guys to judge if it actually is.
I have a few questions about it.
- Behind the stove is a rectangle most stoves I have seen all have been circular. Is this still up to code and fine?
- Inside the stove has these two small pipes coming in from the back.. are they for air flow?
You can see where the owner had his stove. I assume ill have to modify it to fit this or another wood stove.
[Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000 [Hearth.com] Earth stove 3000
You will need an adapter to go from the rectangle to round.
Yes - the two pipes are for air.
Need more info on the pipe and positioning of the stove. What are you dumping into - chimney or a pipe run? Size?
I have a stove just about like that. I have converted it into a paper/box/splitter trash burner outside. I also attempted to make a pool heater with it with marginal success.
