My Blaze King BTJ-503
Glad to see you're getting a handle on the BK, no pun intended.
Your interior, single wall, stove pipe is installed in reverse. The crimped ends should be inserted into the pipe below, preceding it. In your configuration, there is a potential for creosol to drip down the outside of the pipe. This leads me to ask of the remaining stove pipe, including the pass thru ceiling box. I would hope the exterior pipe is class A chimney.
Class A is a double wall with insulation between. Most commonly made from stainless steel.
Good catch!
Thanks for catching the discrepancy in the stove pipe! Looking down into the top of the chimney I see a light colored stone or mortar pipe inside the steel chimney pipe. I hope it is a double-wall class A chimney with insulation.
Pics?
I'm a bit confused.
Happy Thanksgiving everyone. Stay warm as only YOU know how to do. 😊 All night moe, I'm going to research Class A chimneys and I promise to post a picture of what I see in mine. I cleaned out the box and loaded it up just in case the power goes out in the night.
Reactions: all night moe
You too!!
Reactions: guidecca
Pics?
I'm a bit confused.
I didn't do any research yet. We got a warm day yesterday and I got some pictures of the chimney. Can you check these out and evaluate the type of chimney it is? I didn't notice it at the time but the second picture has some writing on it. Thanks!
  • [Hearth.com] My Blaze King BTJ-503
It looks like old Amerivent FB which was their economy line. Give it's age, it may be due for replacement. A professional inspection is a good idea. If it is kept, clean off the storm collar to determine if it is still solid and usable. If so, use a good silicone to seal to the chimney pipe, not roofing tar.
begreen hit the nail on the head. Time for new chimney .....very least, as you stated, have it checked out. A professional is going to want it replaced. That's really not a bad idea though.
Reactions: guidecca
all night moe, was the chimney the way I described it? I think it is more than just stove pipe. I think there is some kind of insulation in it. If things go south here with respect to the electric furnace or a total outage I'll still light the wood to get by until there is some means of heating this place out on the prairie.
It's chimney pipe. There is inner liner insulation and then an air space before the outer skin.
Be cautious if you do use it in an emergency. You don't want to create another.
Looks tom have been possibly overheated, besides the obvious corrosion at the roof collar. The rest may not be that sound either.
Reactions: guidecca
