trailblaze said:
i'm still not sure what problems the original poster is having....someone fill me in cause i might be blind and missed the post.
Are you having over fire problems?
they can be common with these stoves. i had to add an in flu damper. modify the secondary air intake and fiddle with both to make the stove work.
It sounds to me like the classic everburn 'stall', which is the bane of this particular stove. You can built 10 fires with the exact same wood from the same rack of seasoned hardwoods with the same coal bed depths, split orientation, etc. etc. etc. and wind up with 10 different results.
Probably 5+ of those will involve at least 1 'stall' where you have the stove roaring (bypass open), all other factors good (coal bed, everything heated, new splits properly coaled up, etc.), you then close the bypass, hear about 5-10 seconds of the classic everburn 'rumble', clean emissions, then the rumble abruptly stops, the emissions go filthy black....blacker than anything you ever see w/ the bypass open. It can be extremely frustrating, and there is sometimes absolutely NOTHING that can be done about it.
There is the overfire condition as well, aka the everburn 'nuclear' mode where even with the primary air choked down to its lowest levels, the fire runs away on you and the only way to stop it is to start jamming foil up the 2ndary air intake hole.
