Dual material chimney: masonry converts to insulated stainless in attic
jimmyjabjames
31
Nova Scotia, Canada
my masonry chimney needs the top 6 feet or so rebuilt. one mason said we could take the brick down to inside the attic, install a rigid liner with an adaptor plate, and have the remainder as an insulated stainless chimney from the lower attic and through the roof. So from the attic floor to my basement (15-16 feet or so) would be the original masonry chimney (single flue) with a rigid ss liner, and the top would be selkirk superpro 2100 (Canada). it's an INSIDE chimney.
one mason said he never saw anyone do this with a WOOD stove, second guy who suggested it took back his offer for that option when i reminded him it was a wood stove, and a third guy just offered this option and when i mentioned the wood stove he said he has done it before... it seems the manufacturers sell the gear to do it.. he's WETT certified.
is this acceptable? is it recommended for use with a wood stove? (Drolet Baltic) Thanks!
It is acceptable in New York. I have done it. Not sure about where you reside.
Reactions: jimmyjabjames
Yup perfectly fine in the states
Of the two masons who were against it, one is an ICC guy. I don't know if ICC makes these in other models, but the RIS line says there's a masonry adaptor but it's not tested to ULC S-629.
I've since received an email reply from Selkirk and at least one of their models is tested to the ULC standard:
"The SuperVent 2100 Masonry Adapter Kit (MAK) is listed to CAN/ULC-629 standard for 650 degree Celcius chimney systems, serving all fuel such as wood burning for wood insert or free standing woodstove. Have a certified WETT installer do the installation as it must be code compliant."
Can be done using DuraVent’s DuraLiner insulated rigid liner for masonry portion with your choice of factory-built chimney above — DuraTech Canada, DuraTech Premium or Security‘s Secure Temp ASHT or S2100.
Depending on condition of masonry, may be more cost effective to tear-out masonry and start fresh with fact-built all the way up.
