Just purchased a new Drolet Tundra and am interested in how well you folks think they work. It will be replacing a Napoleon 1400 woodstove that has been in use for 16 years. anu info would be appreciated thanks
Come on. Dont spoil the saga. In the other thread you are still very much stumped.They work well. Feed it dry wood and don't expect it to heat 3000 sq ft un-assisted...
Set it up as per the manual, cutting corners usually backfires
I have an older one (first year model)...and a lil bad luck... by the time you get to the end of that thread you'll see things get sorted outCome on. Dont spoil the saga. In the other thread you are still very much stumped.
You guys seem pretty cool. I will probably hang around. Awfully helpful and willing to joke around.I like this guy.
I'm hoping the same is true for the tundra and drolet just sent them all to hearth members to get rid of themWell a few of us anyways. There is a bad apple or two in every crate.![]()
So does this mean they did fix all the issues you guys had? I know about the front fire brick how about the messed up welds? Or different size air inlets?That there is wishful thinking. I bet SBI wished none of the units in the 1st 3 years landed in the lap of a hearth member.
EDIT: Might be wrong there, if it wasn't for the members here, the Tundra may NEVER had been fixed.
I noticed that the other day...gone from the site. In an email response to some questions they told me the Tundra II is supposed to be out mid March...but historically they seem to run a little late on their release dates...Right now in that thread there is the tundra 2. Its not in there website anymore.
Argh. Well I sure don't want to spend all this money only for them to come out with the new improved models month later!I noticed that the other day...gone from the site. In an email response to some questions they told me the Tundra II is supposed to be out mid March...but historically they seem to run a little late on their release dates...
thanks guys for all your responses in Canada we are not allowed to connect a wood stove duct work to our regular forced air furnace ducting so I think this will be a stand alone set up will do a little ducting to get the heat out of the stove room and will run the forced air furnace fan to circulate the heat sny suggestions would be appreciated thanks JackHere is the reply.
"Hi ------
The Tundra II will include a plenum kit and cost more. You might want to decide if you want to wait for the Tundra II, or get a good closeout deal on the Tundra."
So I replied asking if anyhting else will be different.
Thanks for the reply, Can i ask will anything else be different? and an estimated extra costs?
I ask because While a plenum may not be worth an extra $300 to me. some extra controls, and or variable speed blower with the plenum would be.
Thank you very much."
When my hotblast was inspected they had no problem with parallel see pic below. I do see on the manual for tundra it says parrallel not ok in Canada. I plan to hook mine up exactly the same as my hotblast is. Only thing I'm gonna change is to go to the side by side outlets. I don't know how they'd expect it to be useful to anyone with existing ductwork other wise. I have over the minimum 2" duct clearance for over the first 6' and over the minimum 1" for the rest. View attachment 175727View attachment 175728
