How do you know this? We don't know the size of the tank, or the price per gallon.
I've went through a ton of firewood also......not proud of it but to offset my propane usage and to run my propane tank to empty to replace the valves. I have been burning firewood like crazy in my prefab fireplace and puts off very very little heat.
No joke I probably use 4-5completely full loads of firewood in my copper boiler to help heat the house when I'm off work. I would estimate 250lbs of firewood a day I run it.
^ that is my goal
I'm thinking the keyed damper is the way to go since the pipe will be exposed on the outside of the house.
My thinking is that anything that further cools the smoke is probably a bad idea???? Make sense?
No it does not make sense. none what so ever. Do what the install manual says, that's what there for.^ that is my goal
Manual says to put a baro in if draft is over -.08" WCNo it does not make sense. none what so ever. Do what the install manual says, that's what there for.
I'm almost 30. I've finally found the most amazing house on almost 6 acres(in Missouri)
My house is a story 1 1/2 with high ceilings and propane is absolutely KILLING ME!
I filled my tank(80% 770$) dec 31 as of today I'm at 40%. My house is freezing with the thermostat set around 68.
This house seems to be very well built with good insulation but I think the ceiling heights are killing me.
My furnace is a beast- York 160kbtu with 6" flue pipe that works but must be 60%-70%efficient
I am replacing the furnace with a 96% Daikin 90k btu.
I bought a Drolet Heatpro to be the answer to my prayers. I plan on running it everyday and all day long. Anyone own one? What should I be aware of? Should be pickkng up this week and installing in the next couple.
You got itI'm obviously new and keyed damper Bari damper. I'm googling this stuff. What I am coming up with is one is manual one is automatic. If I am wrong....ok that's why I am here.
I have noticed difficultly getting draft on a cold start.
Outside Air Kit (OAK) 4-6" vent from the outside. The last two pics show how to make a "cold air trap"I have noticed difficultly getting draft on a cold start. I read that opening the basement door helps and it defiantly does. Just need to figure out how to avoid having to do that
Open the HE cleanout door, blow a hair dryer on high up the center tube for a few minutes...instant draft on cold starts. Super easy/fast on Caddy/Max Caddy/Tundra/Heatpro with that cleanout door.I need to burn something really fast for the smoke not to come out from everywhere...
