That's interesting, I hate the E stuff for chainsaws and have been running the 91 E free gas. Do you spose the saw is way to lean for the E gas?Caz said:Turns out my Dolmar did not like the same gas that all my other saws run fine on, which is regular gas with ethanol mixed at 40/1.
I just mixed a batch of 93 octane E-Free gas at 50/1 and it runs just fine.
Thanks for the ideas guys.
He'll be back. Unless it was just a stroke of luck putting in a new tank of gas I don't believe fuel was the problem. Might have been the reason if it was stored with ethanol but not the problem otherwise. I'm sure I could dump in ethanol in my saws (not pp saws) but stock and they would run fine. Also I've owned alot of 5100s (4) and I know they run fine on any pump gas.oldspark said:He says it runs fine on the non e-gas, I took him at his word.
Absolutely can be. Much harder to test for. Bar side is easier to do when running but flywheel side is all but impossible. So you would be down to a crank case pressure test with block off plates. Unless it is a real high time saw I would think its most likely something else when this comes up.blades said:can also be caused by air leak through crankshaft bearings
Caz said:Just to be clear, the 40/1 mix with ethanol was not "bad" gas. It was less than 30 days old and i never let gas sit in a saw if i'm not going to be using it for more than a week or two.
Saw is still running fine with the 50/1 E-free mix, but i will check those carb screws this weekend before i start cutting just to be safe. Thanks : )
I respectfully dissagree that a richer oil mix is the source of a hot running saw. Lean air/fuel ratio will cause a hot running saw. I would like you to take that over to racesaws or arboristsite and see what they say. I have run 40:1 for yrs with no trouble.Battenkiller said:Caz said:Just to be clear, the 40/1 mix with ethanol was not "bad" gas. It was less than 30 days old and i never let gas sit in a saw if i'm not going to be using it for more than a week or two.
I have a friend who is a Dolmar sponsored chainsaw carver. He insists on running his saws at 40:1 and has nothing but problems. I took four of his 420s to the local repair shop. All had signs of overheating and three had bad coils caused by the excess heat. He got all four saws back with the recommendation that he keep his saws cleaner and to run 50:1 synthetic as the saw is designed for. He is the stubbornest dude I know and is always right about everything, so I'm sure they will be back in the shop before too long. He never tunes his saws and thinks 40:1 and never running your tank dry are the answers to all saw problems.
Never noticed one of his saws dieseling, though. I'd look a little deeper into things if that happened to one of my saws.
wkpoor said:I respectfully dissagree that a richer oil mix is the source of a hot running saw. Lean air/fuel ratio will cause a hot running saw. I would like you to take that over to racesaws or arboristsite and see what they say. I have run 40:1 for yrs with no trouble.Battenkiller said:Caz said:Just to be clear, the 40/1 mix with ethanol was not "bad" gas. It was less than 30 days old and i never let gas sit in a saw if i'm not going to be using it for more than a week or two.
First off do you know for sure his mix was really 40:1 and second how are they tuned?
Good for youCaz said:wkpoor said:I respectfully dissagree that a richer oil mix is the source of a hot running saw. Lean air/fuel ratio will cause a hot running saw. I would like you to take that over to racesaws or arboristsite and see what they say. I have run 40:1 for yrs with no trouble.Battenkiller said:Caz said:Just to be clear, the 40/1 mix with ethanol was not "bad" gas. It was less than 30 days old and i never let gas sit in a saw if i'm not going to be using it for more than a week or two.
Already did. Read post #6.
http://www.arboristsite.com/chainsaw/184555.htm
