Fixed my squeal:
I have a Harman P68 that we purchased 3 years ago - No problems except we had to replace the ignitor every year. All of a sudden started squealing when the feed auger engaged - contacted dealer who said that it was fines built up in the back panel by the feed lever. Took off the back side panel, removed the fines - did not help the noise at all. Just cleaned the stove the other day so I knew it had nothing to do with carbon build up (I haven't cleaned the stove for up to 3 weeks during a Maine winter and did not affect operation of the stove).
Let stove cycle down and UNPLUG STOVE
(There are electrical ground wires behind the panel) I completely removed the entire back panel (both sides, top and bottom). With the back panel off you will see that the feed auger shaft runs from the stove to a fan motor at the back of the stove just above the exhaust pipe. In between the main body of the stove and the fan there is a collar on the auger shaft with a set screw and a 1" wheel attached to the collar. When the feed auger shaft rotates the wheel rolls against cam levers that activate the trap door for the pellets in the hopper. The wheel is held on by a hex head bolt - the head of the bolt was scraping against the output housing for the shaft. (If Harman had used a carriage bolt instead of a hex there would be no squealing.....) The bolt head was barely touching, however it was enough to drive everybody in the house nuts after a week of squealing.
I loosened the set screw on the collar and moved the collar back towards the fan motor. The collar only moved a 1/8" to 1/4" (very tight tolerance) but it was enough to get the bolt head off of the output housing. Retightened the set screw and no more squealing.
