Rockey said:iceman said:wood dries in summer and winter------- thats the correct answer.... which one will it dry faster, --- depends on your geographical location...
personally, in my area you cant convince me wood will "season" more or less in the summer... our weather typically starts getting nice around end of may beg.. of june... it doesnt really get consistantly "hot" until july and august... sept is a up and down month......however thats when the air starts to become more dry.... winter is bone dry.. but it can get real cold.. so the water in the wood would freeze causing it expand, which would cause cracks and then when the temp get above freezing allow more air in the wood ... right?????? so in the end winter needs summer and summer need winter..... unless you are somewhere that gets extreme dry heat... then of course it would dry faster sitting in dry heat and sun all day... but over here .. we dont have tht and people up in canada do see 90 degrees that much and their winters are longer than ours.... so when does their wood season?
i dont believe there is a right or wrong.. it just depends on YOUR location and climate on which one will get you more...... up here hot summers with high humidity isnt any good.. 60-80 degrees of dry air with a breezy summer is awesome! a warmer winter with temps mostly in 20-40 degree range with not a lot of precip is just as good ...
all i know is around here oak needs 2+ years which is a bummer!!
living out in ohio or the plains i am sure you guys get a lot done in the summer, its very breezy out there ... when i was a kid we always knew when a bad storm (tornado) was coming cause the air would get still!
i am sure there is some formula or guide/chart we could come up with ex... 30 degrees to 80 degrees with x amount of humidity means good/bad evaporation....add in wind of x amount of mph equals ?
I saw that you mentioned it takes 2 years to dry oak. It takes 260 hours at 140 degrees F, 90 hours at 180 deg f, 30 hours at 220 deg F. See a trend here? The more heat you add the quicker it dries. unless Ma has lower summer time temps than winter your argument has no merit. I also saw a commment about freeze drying something. The argument here is not whether or not you can freeze dry somehting its about whether firewood seasons faster in the summer. There has been data and time spent ad nauseum to prove that more heat equals equals quicker seasoning in both lumber and firewood. until I see some documentation proving that freeze drying is quicker than adding heat then that argument is also meritless.
it depends on location did you read that part? and you specific climate.. kiln dried would be the "perfect setup" is that what you have in your wallet/ backyard?
for you it is summer ... and maybe many others for for some it could be in the fall... over here where i am.. our summers, when it gets real hot are just about always humid... the weather alert stay inside humid. about mid sept dry air comes in.. now there are some who live up in the mountains or people who have huge fields to maximize sun exposure but for the most part, we got a lotta trees and mountains/hills
