I have been working on figuring out how to convert from $$Oil$$ to wood, and solve a few problems that my current oil setup is causing. I've done a lot of reading and had some discussions and this is what I came up with. Looking for some constructive comments or pointers on anything I am getting totally wrong.
I have calculated the peak BTU demand of the house several different ways, using calculators going room by room with areas and windows and R values, adding up how much oil and electricity I used last year for heat and getting the degree days and going that route, and doing a basic rough guesstimate based on a few numbers and it always comes out to 100,000 btu/h peak demand +/- about 10%.
The existing system is big old cast iron radiators, gravity flow open system with an expansion tank in the attic. Tank is about 30 feet above boiler in basement, highest radiator is about 20 feet above boiler. Pipes are all iron and steel.
Current boiler is an old retrofitted coal burner burning oil, scary looking. Price of oil is also scary looking, likely to pass $5 a gallon this winter, even higher next winter.
My plan is this:
Put in a gasification boiler in the garage, about 120 feet from the current boiler. Bury insulated 1-1/4" double tube insulated o2 barrier pex about 3 feet down between the house and the garage. Run the boiler loop under pressure with a short bypass and a thermostatic mixing valve at the boiler to prevent thermal shock.
Replace the existing scary boiler with a big flat plate heat exchanger rated at about 120,000 btu/h. sandwitched in lots of Roxul insulation.
Put a sidearm heat exchanger onto the existing electric 100 gallon DHW tank and valve it into the boiler loop. Put a thermostatic mixing valve on the DHW tank so that the line to the house from the tank is fixed at 120 F, set it up to keep the tank at about 140 F via the boiler (or the storage) when they are hot.
When the boiler line gets to the house,have it feed 2 "side loops" for the radiator HE and the DHW HE, basically in parallel but valved with aquastats.
After the 2 side loops, run the boiler loop through a 250,000 btu/h HE in a big unpressurized "open" storage tank (insulated plywood/liner type tank, polyiso insulation, marine plywood, EPDM or custom high temp plastic liner). I've sized it out and I have a perfect spot for a 4,000 gallon tank (4400 gallon total volume, leave 10% for expansion), insulated to R-30 on all sides, any heat lost would just go into the house anyway.
Then the boiler loop goes back to the boiler.
Couple of valves and a pump on a bypass of the boiler loop where it enters the house so that when the boiler isn't hot, nothing runs through the outdoor lines and the storage loops (as needed) with the DHW and radiator HEs.
Pumps and valves etc to make the water go where it needs to go when it needs to go there.
Booster pump on the gravity flow radiator lines to beef it up a touch and to compensate for the flow restriction of the HE.
For the boiler, looking for something that would run at about 250,000 btu/h and hopefully have about an 8 hour burn time at that average rate over the burn, on douglas fir. Maybe the NextGen Biomass 80 or 100? Not sure. 120k btu oil boiler in parallel with wood boiler as backup, only triggered when DHW or radiator needs heat and storage is below 140 and wood isn't burning, ignores and bypasses storage when boilers are in oil burning mode.
UPS power supply for both boilers for times when the power is out with decent sized battery bank (the power goes out for days at a time here sometimes).
I think that's about everything.
Any downside to having such big storage? I worked it out that it gives me a 24 hour cycle time with an 8 hour boiler burn on the coldest days and during the shoulder season, I can get a 48 hour cycle time most of the time, based on storage temps ranging from 140 F to 180 F (40 degree delta), assuming I got the calculations right.
Anyone know how to find data on burn times and average BTU/h of various gasification boilers based on wood species?
Does it make sense to set things up with only one HE in the storage or is it important to use 2, a "charging" one down at the bottom of the tank and a "draw from storage" one up at the top of the tank? (water in tank will be about 60" deep)
My plan is this:
