Wi Thundercat said:"Pellets are pellets, they're all the same!"
Doocrew said:Wi Thundercat said:"Pellets are pellets, they're all the same!"
Ah yes, the box store employee explanation when telling them which brand you prefer to purchase.
SmokeyTheBear said:Here is my favorite pellet related myth.
My stove is clean, I just emptied the burn pot, brushed off the fake brick, and emptied the ash pan.
Shorty said:SmokeyTheBear said:Here is my favorite pellet related myth.
Not funny! Just earlier the neighbor started to have "problems" with his pellet stove. Came over to have me take a look at it. Get over there. What the heck! "When was the last time you cleaned this thing." He said "I empty the ash pan yesterday."
Wi Thundercat said:Amazing! Every stove should come with an invite to this forum!![]()
Czech said:"Your air flow problems thru the pot could be caused by your ash pan door gasket being bad." At least for Quads, busted. The pot doesn't really care where the air comes from.
j-takeman said:SmokeyTheBear said:j-takeman said:SmokeyTheBear said:j-takeman said:Shorty" date="1290747106 said:j-takeman" date="1290745146 said:Shorty" date="1290733314 said:I don't know any myths that have not been demythed yet.
Just the other day I saw a post that someone believes the softwoods burn faster than hardwoods. Sounds like a myth to me?
I thought that was Busted? As long as you turn feed rate down it burns the same amount of time.
That might confirm the myth? I think its busted by other factors. Pellet size and Density.
My testing of Country Pine(softwood) and SIH(hardwood) similar size and density had darn near the same burn length. See chart
There is a reason for that, your stove feeds by volume. So if the different pellets are all the same in terms of size let alone anything else they will cause your stoves timer to record the same burn times.
How do we know for sure the stove feeds by volume?
Put 100,000 .25 inch glass balls into the hooper and run the auger motor until it is primed and they start dropping into a cup, stop the auger feed, then run the auger for a minute.
Repeat the experiment with 100,000 .25 inch lead balls.
Count the contents of the two cups.
Repeat the above experiment a few times, discuss the results.
This is an exercise you can do for yourself.
Interesting. But lead in my hopper?![]()
Czech said:I knew you'd post Smokey! We've been here and done that, I know, poops and giggles. Your last sentence is exactly the config on my Quad, ash clean out doors normally closed during use are the only pass through to the ash pan other than the pot holes.
Delta-T said:myth #1- you can heat your entire home (regardless of those pesky details, like size, build quality, and location) with 1 bag of pellets each day.
myth #B- Hahdwood (thats hardwood for those outside New England) pellets is way less dusty than them softwoods pellet crap.
myth #3- My stove runs way better if I leave the hopper open.
myth #4- I heard this stove (insert whatever unit you like) makes tons of ash.
Czech said:Oh, and by the way. I heat my spilt level with a basement located stove! Yes, the basement is 90 degrees and the above living, dining, and kitchen are hot, and yes the bedrooms are cool.
Czech said:"Don't buy pellets stored outside." Guess I'd call this busted. The Indecks I just unwrapped were wrapped so well I think they could have been stored in a swimming pool and not gotten wet.
Czech said:....
One other myth that a dealer told me when I was shopping many years ago "Set it and forget it!".
