carlan
It went increase how much heat your wood is capable of produce, that is set with the wood you're using.
It will increase how much of that heat your wood produces actually ends up in your house. Without a fan your stove will get to a certain temperature, heat the air around it and make itself a little insulating blanket that reduces how much heat can be conducted from the stove into the air. The heat that can't be conducted goes out the chimney.
The fan blowing cool air onto the stove will disturb that insulating blanket of hot air around the stove, allowing the stove to give up more heat. The stove, now surrounded by cool air can conduct more heat out of the stove itself, instead of just sending it up the chimney.
So yes fans will increase how much heat ends up in your house from the wood you are burning. It's just simple thermodynamics. Think of windchill, do you feel colder on a still air day or on a windy day? The windy day disturbs your warm insulating blanket of air around your skin, allowing more heat to conduct out of your body into the air, making you feel colder. Really stoves are no different.
Sent from my LG-H812 using Tapatalk
Very well said, all other comments were good but this one nailed it in my mind.
