lsucet
Wouldn't that be 0% efficient?
I bet SuperJ had no inkling that his original question would cause so much controversy!
If 0% make you feel better then it is
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
If 0% make you feel better then it is![]()
Well no the input and output are equal so it is 100%Wouldn't that be 0% efficient?
He is right about the fan thing though. By extracting more heat off of the stove and putting it in the room you are increasing one part of efficency. But you are also right in some situations because it could potentially reduce the efficency of the birn by lowering firebox tempsReally.
I'm at the "whatever dude" point with this jackoff.
Really.
Really.
But honestly the differences in efficency either way are typically not that great. It all depends what works best in each situation. People put way to much emphasis on the efficency numbers anyway
Yes, and I think that's what's going on with Highbeam's setup when he says it makes heat better with the fans off. A stronger drafting flue could solve that. BK's have an uncanny ability to burn super low and slow and this is not the time to use fans to try to scavenge every last bit of it.
If you study the design of the BK stoves you will notice the fan kit mostly removes heat from the top of the stove and the stove collar. Of course it's unavoidable that this will slightly lower temperature in the lower firebox but the designers did a good job of minimizing that.
Good plan.I think I'm following the discussion alright... I'm just sitting back, eating popcorn, watching the discussion. It's nice to see a vigorous discussion on something.
I've decided to hold off on the fans for now, mostly cause I blew the budget going for the BK Ashford 30. Easy enough to add them later if necessary.
You would do well to study up on how efficiency is measured. By reducing flue temperature at the same velocity, higher efficiency is achieved. That's what the fans do when they blow across the flue collar and suck the heat right out of it. A cooler flue collar increases the temperature differential between the collar and the hot flue gasses causing more heat to continually be absorbed by the flue collar and blown into the room as hot air.
I think you will eventually understand the thermodynamics involved if you keep studying and learning. This will help you increase the efficiency of your stove as you gain experience with operating the controls that are user adjustable. You will learn when the fans are counter-productive and when they can best be used to your advantage. I know it's not always intuitive but stick with it and you'll get the hang of it.
So if considering an insert that is surrounded by insulation... can you over insulate it with regards to efficiency? Or would you just want your fan to be running faster to bleed off the extra heat trapped in what has effectively become another "shell layer" on the unit?
I'm considering a slightly smaller insert so that I can heavily insulate the sides, back (and potentially the top...while still leaving an inch or two clearance on top) because I don't want to heat my external masonry. What's the best approach here to maximize efficiency?
That's a good question for a new thread. Like most things related to wood-burning, it's dependent upon the particular stove and the particulars of your installation. In general, a highly insulated setup will be more dependent on fans, especially with an insert.
If you post some photos and a bit more detail in a new thread I bet you'll get some good feedback (and some not-so-good feedback). But such is the nature of a free/open forum where anyone can post their opinion whether it's well grounded or not. It's up to each individual to filter the wheat from the chaff.
Another benefit of the fans is they vacuum up the cooler air near the floor. If you don't have an outside air intake, air intake of the stove achieves this function to a limited degree. But the stove fans typically move more air than the natural draft of the stove. I estimate on a med-low burn the normal sized BK's have a natural draft of about 5-7 cfm. The fans are capable of vacuuming a LOT more air than this. So, even on a very low fan setting, they can increase comfort by reducing the temperature stratification of the air in the room. If you have a ceiling fan in the room this won't matter as much but, if not, you can achieve more comfort, more quickly with a slightly lower overall burn rate.
For example, say your family took a weekend get-away and it's been a day or so without the stove active, the house will have cooled down (quite a bit if it's colder out). Now you build a fire and burn on med-high to bring the house back to 72F. After an hour or so the air might be 70F but the walls are still 64F and the windows are colder yet. So there are cold air convection currents flowing down the wall(s) and onto the floor. Rather than continuing to burn on med-high, lower the thermostat slightly and turn the fans on a med-low setting. After a while the thermostat will naturally open a bit due to convection cooling of the fans. Counter-act that by turning the thermostat down a bit more about 5 minutes after turning the fans on. You will find your house gets warmer and more evenly comfortable (without that cold layer by the floor) and heats up faster all while making your load of wood last longer. Turn the fans off when you have achieved the desired comfort level and the thermostat will automatically turn even lower now with the fans off. The "free lunch" you got was recovering heat that would have gone up the flue. Of course, it probably cost $0.0025 in electricity to run the fans.
If all that sounds like too much work you can just burn on high or medium-high without the fans on and lower the thermostat once the room becomes more comfortable but realize this method will consume your load sooner. Recognizing that cutting and transporting wood and bringing it inside is work too, I propose the former strategy of maximizing useable btu's is less labor intensive and offers more comfort and reduces cold air stratification more quickly and with less wood.
Even old highbeam can agree with that! Your description of the intense thermostat management required to use the fans for gaining efficiency is the important caveat. Even a caveman can use fans to increase comfort.
Though only applicable to the stoves that have a thermostat.Comfort, yes, but it takes a little more knowledge to use the fans to reduce wood consumption. Because you need to know to turn the thermostat down a touch when applying the fans.
